[Swift-user] Swift 0.96 - Connection to worker lost exception - reg.
Karthikeyan Balasubramanian karthikeyanb at uchicago.edu
Fri Mar 6 11:27:36 CST 2015
The following exception was thrown by the Swift 0.96, as the process was running. Attached, please find the runxxx folder.
------- Application STDERR --------
exception @ swift-int-staging.k, line: 160
Caused by: Block task failed: Connection to worker lost
org.globus.cog.coaster.TimeoutException: Channel timed out. lastTime=150306-040431.246, now=150306-040632.030, channel=0304-5404390-000001:000000
at org.globus.cog.coaster.channels.AbstractCoasterChannel.checkTimeouts(AbstractCoasterChannel.java:163)
at org.globus.cog.coaster.channels.AbstractCoasterChannel$1.run(AbstractCoasterChannel.java:154)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
k:assign @ swift.k, line: 174
Caused by: Exception in rungenerateGLMC:
    Arguments: [/project/rossc/BMI/glmmodel/././data/input/z20130227_SPK.mat, 0, /project/rossc/BMI/glmmodel/./data/glmaicout/z20130227_SPK_0_AIC.mat, /project/rossc/BMI/glmmodel/./data/glmcausalout/z20130227_SPK_0_CNA.mat]
    Host: midway
    Directory: swift_glm-run016/jobs/r/rungenerateGLMC-eucktf5m
exception @ swift-int-staging.k, line: 165
Caused by:
Any thoughts or suggestions is appreciated.
Thanks.
B.K.
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150306/dc97104d/attachment.html>
Type: application/x-zip-compressed
Desc: run016.zip
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150306/dc97104d/attachment.bin>
More information about the Swift-user mailing list
