[Swift-user] trunk-cobalt block task ended prematurely
Ketan Maheshwari
ketan at mcs.anl.gov
Mon Mar 2 16:14:23 CST 2015
This is the first time I am trying with 0.96.
The generated qsub command indeed does not have "--mode script" which seems
to be causing the issue.
Ketan
On Mon, Mar 2, 2015 at 4:02 PM, Michael Wilde <wilde at anl.gov> wrote:
> Is this the first time you've tried running 0.96 on the BG/Q in subjob
> mode?
> (I.e., has this ever worked before?)
> Did you get a submission script in the run directory (or a log of the
> cobalt qsub or cqsub command) which you could test manually?
> If 0.96 is rejecting the "script" property, it seems possible that 0.96 is
> generating an invalid qsub command and/or submission script.
> - Mike
> On 3/2/15 3:47 PM, Ketan Maheshwari wrote:
> I trying to run on BG/Q with local:cobalt with trunk but Swift crashes
> with the following error:
> Caused by: Exception in bgsh:
> Arguments: [/home/ketan/SwiftApps/subjobs/mpicatsnsleep/mpicatnap,
> /gpfs/mira-home/ketan/SwiftApps/subjobs/mpicatsnsleep/./data.txt,
> /gpfs/mira-home/ketan/SwiftApps/subjobs/mpicatsnsleep/./outdir/f.0002.out,
> 1]
> Host: cluster
> Directory: catsnsleepmpi-run001/jobs/b/bgsh-3nq3uc5m
> exception @ swift-int-staging.k, line: 165
> Caused by:
> exception @ swift-int-staging.k, line: 160
> Caused by: Block task failed: 0302-2109420-000000 Block task ended
> prematurely
> In the log, I see the qsub call being made and a jobid is returned.
> However, I could not figure what is the cause for the task to fail.
> One more thing I noticed when translating from old sites conf to new is
> that the new conf did not accept the property "globus:mode = script".
> A full run log is attached. Thanks for any suggestions.
> Thanks,
> Ketan
> Swift-user mailing listSwift-user at ci.uchicago.eduhttps://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Mathematics and Computer Science Computation Institute
> Argonne National Laboratory The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150302/cc5366e4/attachment.html>
More information about the Swift-user
