[Swift-user] floor(), ceil() and round() issues with v0.8.0
Tim Armstrong
tim.g.armstrong at gmail.com
Sun Jul 26 18:18:03 CDT 2015
Hi Tim,
The return type of those functions changed to float in 0.8.0 as part of a
bigger effort to standardise the Swift library. We tried to keep things
backwards compatible as much as possible but unfortunately there wasn't a
way to do that in this case.
You can get the same effect with toInt(floor(7.8))
- Tim
On 26 July 2015 at 12:59, Timothy Stitt (TGAC) <Timothy.Stitt at tgac.ac.uk>
wrote:
> Dear Swift/T developers & users,
> I've been recompiling a Swift/T script in v0.8.0 (which worked in
> previous versions) but its failing to compile at the line involving the
> floor() command. The error I'm seeing is:
> stc error:
> test.swift:7:6: Cannot assign to t: LVal has type int but RVal has type
> float
> I know that this worked fine in previous versions so I tried to compile
> with the trivial example below and I get the same error:
> import math;
> import io;
> import sys;
> main
> int t = floor(7.8);
> trace(t);
> I substituted floor() for ceil() and round() and got the same error. Is
> there something wrong with the math library or am I doing something really
> stupid that I can't see.
> Thanks,
> Tim.
> *Timothy Stitt PhD* / Head of Scientific Computing
> The Genome Analysis Centre (TGAC), Room 204b
> http://www.tgac.ac.uk/
> p: +44 1603 450378
> e: timothy.stitt at tgac.ac.uk
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150726/83d529a9/attachment.html>
More information about the Swift-user
