[Swift-user] floor(), ceil() and round() issues with v0.8.0
Timothy Stitt (TGAC)
Timothy.Stitt at tgac.ac.uk
Mon Jul 27 04:10:31 CDT 2015
Thanks Tim.
I don't think those changes made their way into the v0.8.0 user guide that I have with my distribution. Your suggestion did work though and my old script is now compiling again.
Cheers.
Timothy Stitt PhD / Head of Scientific Computing
The Genome Analysis Centre (TGAC), Room 204b
http://www.tgac.ac.uk/
p: +44 1603 450378
e: timothy.stitt at tgac.ac.uk<mailto:timothy.stitt at tgac.ac.uk>
From: Tim Armstrong <tim.g.armstrong at gmail.com<mailto:tim.g.armstrong at gmail.com>>
Date: Monday, 27 July 2015 00:18
To: Timothy Stitt <timothy.stitt at tgac.ac.uk<mailto:timothy.stitt at tgac.ac.uk>>
Cc: "swift-user at ci.uchicago.edu<mailto:swift-user at ci.uchicago.edu>" <swift-user at ci.uchicago.edu<mailto:swift-user at ci.uchicago.edu>>
Subject: Re: [Swift-user] floor(), ceil() and round() issues with v0.8.0
Hi Tim,
The return type of those functions changed to float in 0.8.0 as part of a bigger effort to standardise the Swift library. We tried to keep things backwards compatible as much as possible but unfortunately there wasn't a way to do that in this case.
You can get the same effect with toInt(floor(7.8))
- Tim
On 26 July 2015 at 12:59, Timothy Stitt (TGAC) <Timothy.Stitt at tgac.ac.uk<mailto:Timothy.Stitt at tgac.ac.uk>> wrote:
Dear Swift/T developers & users,
I've been recompiling a Swift/T script in v0.8.0 (which worked in previous versions) but its failing to compile at the line involving the floor() command. The error I'm seeing is:
stc error:
test.swift:7:6: Cannot assign to t: LVal has type int but RVal has type float
I know that this worked fine in previous versions so I tried to compile with the trivial example below and I get the same error:
import math;
import io;
import sys;
main
int t = floor(7.8);
trace(t);
I substituted floor() for ceil() and round() and got the same error. Is there something wrong with the math library or am I doing something really stupid that I can't see.
Tim.
p: +44 1603 450378<tel:%2B44%201603%20450378>
Swift-user mailing list
Swift-user at ci.uchicago.edu<mailto:Swift-user at ci.uchicago.edu>
https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150727/2a47f343/attachment.html>
More information about the Swift-user
