[Swift-user] Migrating issues: Swift 0.94 and 0.95
Mihael Hategan
hategan at mcs.anl.gov
Tue Jan 6 14:13:31 CST 2015
None of the errors listed below should affect the functioning of your
program. The first comes from a change in the way swift parses sites.xml
and your solution is right.
The second is a polite note that you don't need to put an at sign before
a function name. You can simply remove the "@".
However, I cannot tell you why the output is empty. It might help if you
posted logs from both the 0.94 and 0.95 runs.
Mihael
On Tue, 2015-01-06 at 20:07 +0000, Karthikeyan Balasubramanian wrote:
> Hi,
> When I ran my swift application in 0.95, the following issues showed up, and the output file ended up empty. However, the same codes ran successfully in 0.94.1, and generated the expected output.
> Issue-1: [Error] midway_rev.xml, line 1, col 9: cvc-elt.1: Cannot find the declaration of element 'config'
> I added the namespace as xmlns="http://www.ci.uchicago.edu/swift/SwiftSites". I am not sure this is the right solution, but the error disappeared afterwards.
> Issue-2: Warning: The @ syntax for function invocation is deprecated
> This is persistent and the output results are empty. Essentially, the output is generated by Matlab, which is then redirected by the bash script. Is there an updated syntax for this?
> Thanks.
> B.K.
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
