[Swift-user] Edison: pbs job starts but Swift unresponsive
Ketan Maheshwari
ketan at mcs.anl.gov
Sat Jan 3 16:29:00 CST 2015
Yes, this was a different run.
Here is the run directory and worker log for a fresh run where I see job in
running stated for ~9 minutes before Swift status shows task active.
Ketan
On Sat, Jan 3, 2015 at 3:53 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Is this from the same run? I don't see delays between the jobs
> completing and the worker being shut down. Can you also post the swift
> log that corresponds to this run and confirm that you see the problem in
> this run?
> Mihael
> On Sat, 2015-01-03 at 15:22 -0600, Ketan Maheshwari wrote:
> > Please find the workerlog attached.
> > Thanks,
> > Ketan
> > On Sat, Jan 3, 2015 at 2:39 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> > > On Tue, 2014-12-30 at 12:49 -0600, Ketan Maheshwari wrote:
> > > > Hi Mihael,
> > > > It takes about 8-9 minutes after the worker starting (ie. queue
> showing
> > > > running status) that the Swift progress text shows active status. In
> the
> > > > active status, one wave of tasks finishes and the status goes back to
> > > > submit state but now no job shows up in the queue.
> > > I see the problem, but I'm not sure what causes it. Can you enable
> > > worker logging and send a worker log?
> > > Mihael
> > > _______________________________________________
> > > Swift-user mailing list
> > > Swift-user at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150103/c557b839/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150103/c557b839/attachment.obj>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150103/c557b839/attachment.bin>
More information about the Swift-user
