[Swift-user] Edison: pbs job starts but Swift unresponsive
Mihael Hategan hategan at mcs.anl.gov
Sat Jan 3 15:53:20 CST 2015
Is this from the same run? I don't see delays between the jobs
completing and the worker being shut down. Can you also post the swift
log that corresponds to this run and confirm that you see the problem in
this run?
Mihael
On Sat, 2015-01-03 at 15:22 -0600, Ketan Maheshwari wrote:
> Please find the workerlog attached.
> Thanks,
> Ketan
> On Sat, Jan 3, 2015 at 2:39 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > On Tue, 2014-12-30 at 12:49 -0600, Ketan Maheshwari wrote:
> > > Hi Mihael,
> > > It takes about 8-9 minutes after the worker starting (ie. queue showing
> > > running status) that the Swift progress text shows active status. In the
> > > active status, one wave of tasks finishes and the status goes back to
> > > submit state but now no job shows up in the queue.
> > I see the problem, but I'm not sure what causes it. Can you enable
> > worker logging and send a worker log?
> > Mihael
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
