[Swift-user] Edison: pbs job starts but Swift unresponsive
Mihael Hategan hategan at mcs.anl.gov
Sat Jan 3 18:09:49 CST 2015
Ok, so I was looking for problems after the first batch of jobs, but
aren't any here.
The 9 minute delay is because workers try all IP addresses that the head
node has, and it may take a long time to time-out through all of them
until a good one is found.
You could force a specific IP address (in your case it's probably
128.55.34.2) using:
<profile namespace="globus" key="internalHostname">128.55.34.2</profile>
Mihael
On Sat, 2015-01-03 at 16:29 -0600, Ketan Maheshwari wrote:
> Yes, this was a different run.
> Here is the run directory and worker log for a fresh run where I see job in
> running stated for ~9 minutes before Swift status shows task active.
> Thanks,
> Ketan
> On Sat, Jan 3, 2015 at 3:53 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > Is this from the same run? I don't see delays between the jobs
> > completing and the worker being shut down. Can you also post the swift
> > log that corresponds to this run and confirm that you see the problem in
> > this run?
> > Mihael
> > On Sat, 2015-01-03 at 15:22 -0600, Ketan Maheshwari wrote:
> > > Please find the workerlog attached.
> > > Thanks,
> > > Ketan
> > > On Sat, Jan 3, 2015 at 2:39 PM, Mihael Hategan <hategan at mcs.anl.gov>
> > wrote:
> > > > On Tue, 2014-12-30 at 12:49 -0600, Ketan Maheshwari wrote:
> > > > > Hi Mihael,
> > > > > It takes about 8-9 minutes after the worker starting (ie. queue
> > showing
> > > > > running status) that the Swift progress text shows active status. In
> > the
> > > > > active status, one wave of tasks finishes and the status goes back to
> > > > > submit state but now no job shows up in the queue.
> > > > I see the problem, but I'm not sure what causes it. Can you enable
> > > > worker logging and send a worker log?
> > > > Mihael
> > > > _______________________________________________
> > > > Swift-user mailing list
> > > > Swift-user at ci.uchicago.edu
> > > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
