[Swift-user] Swift/MPI & OpenFoam
Justin M Wozniak
wozniak at mcs.anl.gov
Wed Feb 25 09:51:27 CST 2015
Swift/T has a feature to call an MPI library:
http://swift-lang.org/Swift-T/leaf.html#_complete_example_8_calling_an_mpi_library
Does that seem appropriate?
On 02/25/2015 10:12 AM, Matthew Shaxted wrote:
> Hi all,
> A few questions about Swift’s interaction with MPI – specifically
> related to OpenFoam CFD:
> To date, we are running OpenFoam CFD jobs on a single machine at the
> moment, but are looking to scale up computation by way of OpenFoam’s
> MPI support.
> We discussed a strategy of enabling Lustre or a similar file system
> across our internal resources, connecting our worker nodes to the head
> node via an MPI listener, and submitting/running the jobs via
> OpenFoam’s MPI run command.
> Does Swift support a connection via MPI?
> Perhaps Swift can help manage setting up the in the same way a
> worker.pl is setup for coaster-service?
> Thanks for any insights.
> Matthew
> MATTHEW SHAXTED
> SKIDMORE, OWINGS & MERRILL LLP
> 224 SOUTH MICHIGAN AVENUE
> CHICAGO, IL 60604
> T (312) 360-4368
> MATTHEW.SHAXTED at SOM.COM <mailto:MATTHEW.SHAXTED at SOM.COM>
> cid:image001.png at 01CF9071.6FB46030 <http://www.som.com/>
> The information contained in this communication may be confidential,
> is intended only for the use of the recipient(s) named above, and may
> be legally privileged. If the reader of this message is not the
> intended recipient, you are hereby notified that any dissemination,
> distribution, or copying of this communication, or any of its
> contents, is strictly prohibited and may be unlawful. If you have
> received this communication in error, please return it to the
> sender immediately and delete the original message and any copy of
> it from your computer system. If you have any questions concerning
> this message, please contact the sender.
> http://intranet.som.com/common/admin/file.cfm?f=%2Fresources%2Fcontent%2F5%2F0%2F4%2F4%2F6%2F4%2F0%2F3%2Fdocuments%2Fimagea560bf%2Egif%406e10073b%2E30854c37
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150225/cdbb54e5/attachment.html>
Name: not available
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150225/cdbb54e5/attachment.png>
Name: not available
Type: image/gif
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20150225/cdbb54e5/attachment.gif>
More information about the Swift-user
