[Swift-user] question about xsede
Michael Wilde wilde at anl.gov
Mon Sep 29 09:24:23 CDT 2014
Justin, in your sites entry below, this line looks suspect:
<workdirectory>/brashear/usrname</workdirectory>
That needs to be the name of a writable directory.
- Mike
On 9/28/14, 6:03 PM, Justin bbt wrote:
> changing the queue to "batch", I get this
> Execution failed:
> Exception in simulate:
>     Arguments: [--timesteps, 1, --range, 100, --nvalues, 5]
>     Host: black
>   Directory: p4-run026/jobs/5/simulate-58d6x2yl
> exception @ swift-int-staging.k, line: 181
> Caused by:
> exception @ swift-int-staging.k, line: 177
> Caused by: null
> Caused by:
> org.globus.cog.abstraction.impl.common.execution.JobException: Job
> failed with an exit code of 1
> On Sat, Sep 27, 2014 at 5:17 PM, Mihael Hategan <hategan at mcs.anl.gov
> <mailto:hategan at mcs.anl.gov>> wrote:
>     Hi Justin,
>     Is there a queue named "normal" on that machine (qstat -q should tell
>     you)?
>     Mihael
>     On Sat, 2014-09-27 at 15:41 -0400, Justin bbt wrote:
>     > So, I am using this config
>     > <pool handle="black">
>     >     <execution provider="coaster" jobmanager="local:pbs"
>     URL="none"/>
>     >     <profile namespace="env"
>     key="PATHPREFIX">{env.PWD}/../app</profile>
>     >     <profile namespace="globus" key="jobsPerNode">1</profile>
>     >     <profile namespace="globus" key="queue">normal</profile>
>     > <profile namespace="globus" key="ppn">16</profile>
>     >   <profile namespace="globus" key="maxWallTime">00:01:00</profile>
>     >     <profile namespace="globus" key="maxTime">3600</profile>
>     key="lowOverAllocation">100</profile>
>     key="highOverAllocation">100</profile>
>     >     <profile namespace="globus" key="slots">2</profile>
>     >     <profile namespace="globus" key="maxNodes">1</profile>
>     >     <profile namespace="globus" key="nodeGranularity">1</profile>
>     >     <profile namespace="karajan" key="jobThrottle">.320</profile>
>     >     <profile namespace="karajan" key="initialScore">10000</profile>
>     >   <profile namespace="globus" key="slots">1</profile>
>     >    <profile namespace="globus" key="project">TG-CCR134513</profile>
>     >       <profile namespace="swift" key="stagingMethod">local</profile>
>     > <filesystem provider="local" />
>     > </pool>
>     > but, it does not work and give this error :
>     > Swift 0.95 RC6 swift-r7900 cog-r3908
>     > RunID: run011
>     > Warning: The @ syntax for function invocation is deprecated
>     > [Error] sites.xml, line 2, col 10: cvc-elt.1: Cannot find the
>     declaration
>     > of element 'config'.
>     > Progress: Sat, 27 Sep 2014 15:35:52-0400
>     > Could not submit job (qsub reported an exit code of 170).
>     > qsub: Unknown queue MSG=cannot locate queue
>     > Execution failed:
>     >     Host: black
>     >     Directory: p4-run011/jobs/s/simulate-sdm041yl
>     > Caused by:
>     > Caused by: Block task failed: Error submitting block task
>     org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
>     Could
>     > at
>     org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
>     > at
>     org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
>     > at
>     org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:61)
>     > at
>     org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.run(BlockTaskSubmitter.java:70)
>     > Caused by:
>     org.globus.cog.abstraction.impl.scheduler.common.ProcessException:
>     Could
>     > at
>     org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:113)
>     > at
>     org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
>     > ... 3 more
>     > also, in some configs I saw this. But I dont know what this is
>     and what
>     > values should I set to
>     > key="providerAttributes">pbs.aprun;pbs.mpp;depth=32</profile>
>     > On Tue, Sep 23, 2014 at 6:22 PM, Justin bbt <justinbbt at gmail.com
>     <mailto:justinbbt at gmail.com>> wrote:
>     > > Thank you very much.
>     > > I am actually using the Blacklight, which I guess is PBS based.
>     > > So, should I use the Crays tutorial and setting ?
>     > > http://swift-lang.org/tutorials/cray/tutorial.html
>     > > On Tue, Sep 23, 2014 at 10:31 AM, Ketan Maheshwari
>     <ketan at mcs.anl.gov <mailto:ketan at mcs.anl.gov>>
>     > > wrote:
>     > >> Hi Justin,
>     > >> If you are using xsede Stampede regular nodes (non xeon phi),
>     here is a
>     > >> site configuration that has worked for me in the past,
>     connecting over ssh
>     > >> to slurm:
>     > >> <?xml version="1.0" encoding="UTF-8"?>
>     > >> <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
>     > >>  <pool handle="stampede">
>     > >>    <execution provider="coaster" jobmanager="ssh-cl:slurm" url="
>     > >> stampede.tacc.utexas.edu <http://stampede.tacc.utexas.edu>"/>
>     > >>    <profile namespace="globus" key="ppn">1</profile>
>     > >>    <profile namespace="globus" key="maxTime">7500</profile>
>     key="maxwalltime">00:10:00</profile>
>     key="lowOverallocation">100</profile>
>     key="highOverallocation">100</profile>
>     key="project">TG-EAR130015</profile>
>     > >>    <profile namespace="karajan" key="jobThrottle">.3199</profile>
>     > >> <workdirectory>/tmp/{env.USER}/swift.work</workdirectory>
>     > >>   </pool>
>     > >> </config>
>     > >> You will need to replace project id with yours.
>     > >> Thanks,
>     > >> Ketan
>     > >> On Mon, Sep 22, 2014 at 8:32 PM, Justin bbt
>     <justinbbt at gmail.com <mailto:justinbbt at gmail.com>> wrote:
>     > >>> Hi
>     > >>> If I want to use resources on the xsede
>     > >>> https://www.xsede.org/overview
>     > >>> which site config should I use ?
>     > >>> _______________________________________________
>     > >>> Swift-user mailing list
>     > >>> Swift-user at ci.uchicago.edu <mailto:Swift-user at ci.uchicago.edu>
>     https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140929/40e6473f/attachment.html>
More information about the Swift-user mailing list
