[Swift-user] question about xsede
Justin bbt justinbbt at gmail.com
Sun Sep 28 18:03:19 CDT 2014
changing the queue to "batch", I get this
Execution failed:
Exception in simulate:
    Arguments: [--timesteps, 1, --range, 100, --nvalues, 5]
    Host: black
    Directory: p4-run026/jobs/5/simulate-58d6x2yl
exception @ swift-int-staging.k, line: 181
Caused by:
exception @ swift-int-staging.k, line: 177
Caused by: null
Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
Job failed with an exit code of 1
On Sat, Sep 27, 2014 at 5:17 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Hi Justin,
> Is there a queue named "normal" on that machine (qstat -q should tell
> you)?
> Mihael
> On Sat, 2014-09-27 at 15:41 -0400, Justin bbt wrote:
> > So, I am using this config
> > <pool handle="black">
> >     <execution provider="coaster" jobmanager="local:pbs" URL="none"/>
> >     <profile namespace="env"
> key="PATHPREFIX">{env.PWD}/../app</profile>
> >     <profile namespace="globus" key="jobsPerNode">1</profile>
> >     <profile namespace="globus" key="queue">normal</profile>
> > <profile namespace="globus"  key="ppn">16</profile>
> >   <profile namespace="globus" key="maxWallTime">00:01:00</profile>
> >     <profile namespace="globus" key="maxTime">3600</profile>
> >     <profile namespace="globus" key="lowOverAllocation">100</profile>
> >     <profile namespace="globus" key="highOverAllocation">100</profile>
> >     <profile namespace="globus" key="slots">2</profile>
> >     <profile namespace="globus" key="maxNodes">1</profile>
> >     <profile namespace="globus" key="nodeGranularity">1</profile>
> >     <profile namespace="karajan" key="jobThrottle">.320</profile>
> >     <profile namespace="karajan" key="initialScore">10000</profile>
> >   <profile namespace="globus" key="slots">1</profile>
> >    <profile namespace="globus"  key="project">TG-CCR134513</profile>
> >     <workdirectory>/brashear/usrname</workdirectory>
> >       <profile namespace="swift" key="stagingMethod">local</profile>
> > <filesystem provider="local" />
> > </pool>
> > but, it does not work and give this error :
> > Swift 0.95 RC6 swift-r7900 cog-r3908
> > RunID: run011
> > Warning: The @ syntax for function invocation is deprecated
> > [Error] sites.xml, line 2, col 10: cvc-elt.1: Cannot find the declaration
> > of element 'config'.
> > Progress: Sat, 27 Sep 2014 15:35:52-0400
> > Could not submit job (qsub reported an exit code of 170).
> > qsub: Unknown queue MSG=cannot locate queue
> > Execution failed:
> >     Host: black
> >     Directory: p4-run011/jobs/s/simulate-sdm041yl
> > Caused by:
> > Caused by: Block task failed: Error submitting block task
> > org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> Could
> > at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
> > at
> org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
> > at
> org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:61)
> > at
> org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.run(BlockTaskSubmitter.java:70)
> > Caused by:
> > org.globus.cog.abstraction.impl.scheduler.common.ProcessException: Could
> > at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:113)
> > at
> org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
> > ... 3 more
> > also, in some configs I saw this. But I dont know what this is and what
> > values should I set to
> > key="providerAttributes">pbs.aprun;pbs.mpp;depth=32</profile>
> > On Tue, Sep 23, 2014 at 6:22 PM, Justin bbt <justinbbt at gmail.com> wrote:
> > > Thank you very much.
> > > I am actually using the Blacklight, which I guess is PBS based.
> > > So, should I use the Crays tutorial and setting ?
> > > http://swift-lang.org/tutorials/cray/tutorial.html
> > > On Tue, Sep 23, 2014 at 10:31 AM, Ketan Maheshwari <ketan at mcs.anl.gov>
> > > wrote:
> > >> Hi Justin,
> > >> If you are using xsede Stampede regular nodes (non xeon phi), here is
> a
> > >> site configuration that has worked for me in the past, connecting
> over ssh
> > >> to slurm:
> > >> <?xml version="1.0" encoding="UTF-8"?>
> > >> <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
> > >>  <pool handle="stampede">
> > >>    <execution provider="coaster" jobmanager="ssh-cl:slurm" url="
> > >> stampede.tacc.utexas.edu"/>
> > >>    <profile namespace="globus"  key="ppn">1</profile>
> > >>    <profile namespace="globus"  key="maxTime">7500</profile>
> > >>    <profile namespace="globus"  key="maxwalltime">00:10:00</profile>
> > >>    <profile namespace="globus"  key="lowOverallocation">100</profile>
> > >>    <profile namespace="globus"  key="highOverallocation">100</profile>
> > >>    <profile namespace="globus"  key="project">TG-EAR130015</profile>
> > >>    <profile namespace="karajan" key="jobThrottle">.3199</profile>
> > >>    <workdirectory>/tmp/{env.USER}/swift.work</workdirectory>
> > >>   </pool>
> > >> </config>
> > >> You will need to replace project id with yours.
> > >> Thanks,
> > >> Ketan
> > >> On Mon, Sep 22, 2014 at 8:32 PM, Justin bbt <justinbbt at gmail.com>
> wrote:
> > >>> Hi
> > >>> If I want to use resources on the xsede
> > >>> https://www.xsede.org/overview
> > >>> which site config should I use ?
> > >>> _______________________________________________
> > >>> Swift-user mailing list
> > >>> Swift-user at ci.uchicago.edu
> > >>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140928/5fec3f66/attachment.html>
More information about the Swift-user mailing list
