[Swift-user] question about xsede
Justin bbt justinbbt at gmail.com
Sat Sep 27 14:41:53 CDT 2014
So, I am using this config
<pool handle="black">
    <execution provider="coaster" jobmanager="local:pbs" URL="none"/>
    <profile namespace="env"    key="PATHPREFIX">{env.PWD}/../app</profile>
    <profile namespace="globus" key="jobsPerNode">1</profile>
    <profile namespace="globus" key="queue">normal</profile>
<profile namespace="globus"  key="ppn">16</profile>
  <profile namespace="globus" key="maxWallTime">00:01:00</profile>
    <profile namespace="globus" key="maxTime">3600</profile>
    <profile namespace="globus" key="lowOverAllocation">100</profile>
    <profile namespace="globus" key="highOverAllocation">100</profile>
    <profile namespace="globus" key="slots">2</profile>
    <profile namespace="globus" key="maxNodes">1</profile>
    <profile namespace="globus" key="nodeGranularity">1</profile>
    <profile namespace="karajan" key="jobThrottle">.320</profile>
    <profile namespace="karajan" key="initialScore">10000</profile>
  <profile namespace="globus" key="slots">1</profile>
   <profile namespace="globus"  key="project">TG-CCR134513</profile>
    <workdirectory>/brashear/usrname</workdirectory>
      <profile namespace="swift" key="stagingMethod">local</profile>
<filesystem provider="local" />
</pool>
but, it does not work and give this error :
Swift 0.95 RC6 swift-r7900 cog-r3908
RunID: run011
Warning: The @ syntax for function invocation is deprecated
[Error] sites.xml, line 2, col 10: cvc-elt.1: Cannot find the declaration
of element 'config'.
Progress: Sat, 27 Sep 2014 15:35:52-0400
Could not submit job (qsub reported an exit code of 170).
qsub: Unknown queue MSG=cannot locate queue
Execution failed:
Exception in simulate:
    Arguments: [--timesteps, 1, --range, 100, --nvalues, 5]
    Host: black
    Directory: p4-run011/jobs/s/simulate-sdm041yl
exception @ swift-int-staging.k, line: 181
Caused by:
exception @ swift-int-staging.k, line: 177
Caused by: Block task failed: Error submitting block task
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException: Could
at
org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:63)
at
org.globus.cog.abstraction.impl.common.AbstractTaskHandler.submit(AbstractTaskHandler.java:45)
at
org.globus.cog.abstraction.impl.common.task.ExecutionTaskHandler.submit(ExecutionTaskHandler.java:61)
at
org.globus.cog.abstraction.coaster.service.job.manager.BlockTaskSubmitter.run(BlockTaskSubmitter.java:70)
Caused by:
org.globus.cog.abstraction.impl.scheduler.common.ProcessException: Could
at
org.globus.cog.abstraction.impl.scheduler.common.AbstractExecutor.start(AbstractExecutor.java:113)
at
org.globus.cog.abstraction.impl.scheduler.common.AbstractJobSubmissionTaskHandler.submit(AbstractJobSubmissionTaskHandler.java:53)
... 3 more
also, in some configs I saw this. But I dont know what this is and what
values should I set to
key="providerAttributes">pbs.aprun;pbs.mpp;depth=32</profile>
On Tue, Sep 23, 2014 at 6:22 PM, Justin bbt <justinbbt at gmail.com> wrote:
> Thank you very much.
> I am actually using the Blacklight, which I guess is PBS based.
> So, should I use the Crays tutorial and setting ?
> http://swift-lang.org/tutorials/cray/tutorial.html
> On Tue, Sep 23, 2014 at 10:31 AM, Ketan Maheshwari <ketan at mcs.anl.gov>
> wrote:
>> Hi Justin,
>> If you are using xsede Stampede regular nodes (non xeon phi), here is a
>> site configuration that has worked for me in the past, connecting over ssh
>> to slurm:
>> <?xml version="1.0" encoding="UTF-8"?>
>> <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
>>  <pool handle="stampede">
>>    <execution provider="coaster" jobmanager="ssh-cl:slurm" url="
>> stampede.tacc.utexas.edu"/>
>>    <profile namespace="globus"  key="ppn">1</profile>
>>    <profile namespace="globus"  key="maxTime">7500</profile>
>>    <profile namespace="globus"  key="maxwalltime">00:10:00</profile>
>>    <profile namespace="globus"  key="lowOverallocation">100</profile>
>>    <profile namespace="globus"  key="highOverallocation">100</profile>
>>    <profile namespace="globus"  key="project">TG-EAR130015</profile>
>>    <profile namespace="karajan" key="jobThrottle">.3199</profile>
>>    <workdirectory>/tmp/{env.USER}/swift.work</workdirectory>
>>   </pool>
>> </config>
>> You will need to replace project id with yours.
>> Thanks,
>> Ketan
>> On Mon, Sep 22, 2014 at 8:32 PM, Justin bbt <justinbbt at gmail.com> wrote:
>>> Hi
>>> If I want to use resources on the xsede
>>> https://www.xsede.org/overview
>>> which site config should I use ?
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140927/a2bf2662/attachment.html>
More information about the Swift-user mailing list
