[Swift-user] question about xsede
Michael Wilde wilde at anl.gov
Tue Sep 23 17:30:48 CDT 2014
Justin,
Blacklight is an SGI machine, and thus a more standard PBS machine to
which the Cray-specific sites file settings do not apply.
It does seem to have a few quirks, though, as describe at:
   https://portal.xsede.org/psc-blacklight#running
In particular, the page above suggests using "-l ncpus=N" where N is the
number of CPUS desired and a multiple of 16.  But by default Swift will
generate "-l nodes=n" where n is the number of nodes.
So we'll need to either do some testing (once we get on the machine) or
send you our best guess of the right sites settings and work with you to
test them for us.
We'll look into this further and report back.
- Mike
On 9/23/14, 5:22 PM, Justin bbt wrote:
> Thank you very much.
> I am actually using the Blacklight, which I guess is PBS based.
> So, should I use the Crays tutorial and setting ?
> http://swift-lang.org/tutorials/cray/tutorial.html
> On Tue, Sep 23, 2014 at 10:31 AM, Ketan Maheshwari <ketan at mcs.anl.gov
> <mailto:ketan at mcs.anl.gov>> wrote:
>     Hi Justin,
>     If you are using xsede Stampede regular nodes (non xeon phi), here
>     is a site configuration that has worked for me in the past,
>     connecting over ssh to slurm:
>     <?xml version="1.0" encoding="UTF-8"?>
>     <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
>      <pool handle="stampede">
>        <execution provider="coaster" jobmanager="ssh-cl:slurm"
>     url="stampede.tacc.utexas.edu <http://stampede.tacc.utexas.edu>"/>
>        <filesystem provider="local" />
>        <profile namespace="globus"  key="jobsPerNode">1</profile>
>        <profile namespace="globus"  key="ppn">1</profile>
>        <profile namespace="globus"  key="maxTime">7500</profile>
>        <profile namespace="globus"  key="maxwalltime">00:10:00</profile>
>        <profile namespace="globus"  key="lowOverallocation">100</profile>
>        <profile namespace="globus"  key="highOverallocation">100</profile>
>        <profile namespace="globus"  key="queue">normal</profile>
>        <profile namespace="globus"  key="nodeGranularity">1</profile>
>        <profile namespace="globus"  key="maxNodes">1</profile>
>        <profile namespace="globus" key="slots">1</profile>
>        <profile namespace="globus"  key="project">TG-EAR130015</profile>
>        <profile namespace="karajan" key="jobThrottle">.3199</profile>
>        <profile namespace="karajan" key="initialScore">10000</profile>
>      <workdirectory>/tmp/{env.USER}/swift.work</workdirectory>
>       </pool>
>     </config>
>     You will need to replace project id with yours.
>     Thanks,
>     Ketan
>     On Mon, Sep 22, 2014 at 8:32 PM, Justin bbt <justinbbt at gmail.com
>     <mailto:justinbbt at gmail.com>> wrote:
>         Hi
>         If I want to use resources on the xsede
>         https://www.xsede.org/overview
>         which site config should I use ?
>         _______________________________________________
>         Swift-user mailing list
>         Swift-user at ci.uchicago.edu <mailto:Swift-user at ci.uchicago.edu>
>         https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Mathematics and Computer Science          Computation Institute
Argonne National Laboratory               The University of Chicago
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140923/d0616ab6/attachment.html>
More information about the Swift-user mailing list
