[Swift-user] question about xsede
Justin bbt justinbbt at gmail.com
Tue Sep 23 17:22:07 CDT 2014
Thank you very much.
I am actually using the Blacklight, which I guess is PBS based.
So, should I use the Crays tutorial and setting ?
http://swift-lang.org/tutorials/cray/tutorial.html
On Tue, Sep 23, 2014 at 10:31 AM, Ketan Maheshwari <ketan at mcs.anl.gov>
wrote:
> Hi Justin,
> If you are using xsede Stampede regular nodes (non xeon phi), here is a
> site configuration that has worked for me in the past, connecting over ssh
> to slurm:
> <?xml version="1.0" encoding="UTF-8"?>
> <config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
>  <pool handle="stampede">
>    <execution provider="coaster" jobmanager="ssh-cl:slurm" url="
> stampede.tacc.utexas.edu"/>
>    <filesystem provider="local" />
>    <profile namespace="globus"  key="jobsPerNode">1</profile>
>    <profile namespace="globus"  key="ppn">1</profile>
>    <profile namespace="globus"  key="maxTime">7500</profile>
>    <profile namespace="globus"  key="maxwalltime">00:10:00</profile>
>    <profile namespace="globus"  key="lowOverallocation">100</profile>
>    <profile namespace="globus"  key="highOverallocation">100</profile>
>    <profile namespace="globus"  key="queue">normal</profile>
>    <profile namespace="globus"  key="nodeGranularity">1</profile>
>    <profile namespace="globus"  key="maxNodes">1</profile>
>    <profile namespace="globus" key="slots">1</profile>
>    <profile namespace="globus"  key="project">TG-EAR130015</profile>
>    <profile namespace="karajan" key="jobThrottle">.3199</profile>
>    <profile namespace="karajan" key="initialScore">10000</profile>
>    <workdirectory>/tmp/{env.USER}/swift.work</workdirectory>
>   </pool>
> </config>
> You will need to replace project id with yours.
> Thanks,
> Ketan
> On Mon, Sep 22, 2014 at 8:32 PM, Justin bbt <justinbbt at gmail.com> wrote:
>> Hi
>> If I want to use resources on the xsede
>> https://www.xsede.org/overview
>> which site config should I use ?
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140923/a59f1ca3/attachment.html>
More information about the Swift-user mailing list
