[Swift-user] Java version to build and run Swift
Ketan Maheshwari
ketan at mcs.anl.gov
Fri May 30 11:54:12 CDT 2014
PS: Just tested with Oracle java 1.7.07 on My Mac and a Ubuntu machine.
Worked for me:
$ ~/swift-devel/cog/modules/swift/dist/swift-svn/bin/swift
~/swift-devel/cog/modules/swift/examples/misc/hello.swift
Swift trunk swift-r7889 cog-r3907
RunID: run001
Progress: Fri, 30 May 2014 11:52:48-0500
Final status:Fri, 30 May 2014 11:52:48-0500 Finished successfully:1
On Fri, May 30, 2014 at 11:47 AM, Ketan Maheshwari <ketan at mcs.anl.gov>
wrote:
> Hi Guilherme,
> Swift should work with Sun/Oracle java 1.6+. Which version of java are you
> using? Can you send the command line for swift invocation that you are
> using.
> Thanks,
> Ketan
> On Fri, May 30, 2014 at 9:17 AM, Guilherme Gall <gmgall at lncc.br> wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi all,
>> What version of Java should I use to build and run Swift trunk?
>> I'm getting a NullPointerException trying to run even the simplest
>> script in the examples directory (hello.swift).
>> Thanks in advance,
>> Guilherme Gall
>> CSR/LNCC
>> GPG Public Key ID: A65ED0D5
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.4.14 (GNU/Linux)
>> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
>> iQEcBAEBAgAGBQJTiJMXAAoJEG9WBlOmXtDVYVEH/0KJVXA+u3RZ+j3ATbJlC24e
>> IXeKgOg6apxmPec/w41YvkuUSbWZRaSdpCw+GDMhk/NvgZxLHhbySIRlpsd/94OP
>> zt8vsGWiCMAZNU3Jnol5QEWupWwq3cBEV7Z9wMjeumCm77owdowNSdLnTZYjdtKa
>> tlx3DvnDci+lfJIHXqxNFV+nOcHeiSX2KL2igM6DMFs531D7fgps9tZHZJis87jF
>> cRlPwbFaLjeaxi17GKBGoEduonFlKfT3qkZbQB8yCQPDaA/FufjpvjRHydSmW9kg
>> Oz9+QxFr03hSSbxEQ1+dSRDq6oRyAlKxXK33ZUyGDputMcKOwn928737WbCYhz8=
>> =3ory
>> -----END PGP SIGNATURE-----
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140530/28d0801d/attachment.html>
More information about the Swift-user
