[Swift-user] Java version to build and run Swift
Ketan Maheshwari
ketan at mcs.anl.gov
Fri May 30 11:47:33 CDT 2014
Hi Guilherme,
Swift should work with Sun/Oracle java 1.6+. Which version of java are you
using? Can you send the command line for swift invocation that you are
using.
Ketan
On Fri, May 30, 2014 at 9:17 AM, Guilherme Gall <gmgall at lncc.br> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi all,
> What version of Java should I use to build and run Swift trunk?
> I'm getting a NullPointerException trying to run even the simplest
> script in the examples directory (hello.swift).
> Thanks in advance,
> Guilherme Gall
> CSR/LNCC
> GPG Public Key ID: A65ED0D5
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.14 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
> iQEcBAEBAgAGBQJTiJMXAAoJEG9WBlOmXtDVYVEH/0KJVXA+u3RZ+j3ATbJlC24e
> IXeKgOg6apxmPec/w41YvkuUSbWZRaSdpCw+GDMhk/NvgZxLHhbySIRlpsd/94OP
> zt8vsGWiCMAZNU3Jnol5QEWupWwq3cBEV7Z9wMjeumCm77owdowNSdLnTZYjdtKa
> tlx3DvnDci+lfJIHXqxNFV+nOcHeiSX2KL2igM6DMFs531D7fgps9tZHZJis87jF
> cRlPwbFaLjeaxi17GKBGoEduonFlKfT3qkZbQB8yCQPDaA/FufjpvjRHydSmW9kg
> Oz9+QxFr03hSSbxEQ1+dSRDq6oRyAlKxXK33ZUyGDputMcKOwn928737WbCYhz8=
> =3ory
> -----END PGP SIGNATURE-----
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140530/a680e46b/attachment.html>
More information about the Swift-user
