[Swift-user] Java version to build and run Swift
Mihael Hategan
hategan at mcs.anl.gov
Fri May 30 13:19:43 CDT 2014
On Fri, 2014-05-30 at 11:17 -0300, Guilherme Gall wrote:
> Hi all,
> What version of Java should I use to build and run Swift trunk?
Oracle is the gold standard. The IBM JDK should work. GCJ never did.
The version should be >= 1.6.
> I'm getting a NullPointerException trying to run even the simplest
> script in the examples directory (hello.swift).
Trunk may have its moments of instability. However, I cannot reproduce
your problem with trunk, so it might be helpful if you posted some more
details, such as the log or a stack trace if that is not possible.
Mihael
More information about the Swift-user
