[Swift-user] Data transfer error
Bronevetsky, Greg
bronevetsky1 at llnl.gov
Wed May 21 18:59:11 CDT 2014
Where should I look to debug the following error?
Caused by: Block task failed: 0521-5404270-000009 Block task ended prematurely
Greg Bronevetsky
Lawrence Livermore National Lab
(925) 424-5756
bronevetsky at llnl.gov
http://greg.bronevetsky.com
-----Original Message-----
From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
Sent: Wednesday, May 21, 2014 2:10 PM
To: Bronevetsky, Greg
Cc: swift-user at ci.uchicago.edu
Subject: Re: [Swift-user] Data transfer error
Sorry for the late reply (to your previous mail mentioning this).
I don't know what the answer to your question is. It shouldn't be happening.
However, a directory called <scriptName>-<timestamp>-<runid>.d should be created by swift. That directory should contain one or more *.info file which may contain a few more details.
Mihael
On Wed, 2014-05-21 at 20:50 +0000, Bronevetsky, Greg wrote:
> Related question: what causes the following error?
> Caused by: Failed to move output file
> solver_bicg.precond_diag.mtx_nasa1824/FI/blocks/block_10 to shared directory I see the file in the swift work directory and the path solver_bicg.precond_diag.mtx_nasa1824/FI/blocks/ exists in the directory where I run the script.
> Greg Bronevetsky
> (925) 424-5756
> bronevetsky at llnl.gov<mailto:bronevetsky at llnl.gov>
> From: Bronevetsky, Greg
> Sent: Tuesday, May 20, 2014 2:11 PM
> To: swift-user at ci.uchicago.edu
> Subject: Data transfer error
> I sometimes get the following error in my Swift runs:
> solver_bicg.precond_diag.mtx_nasa1824/mt_fmodel/fm_n/lm_local/allStats to shared directory What causes it and how can I avoid it?
> Greg Bronevetsky
> (925) 424-5756
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
