[Swift-user] Data transfer error
Mihael Hategan
hategan at mcs.anl.gov
Thu May 22 02:22:36 CDT 2014
There are a number of places. I think this got improved a bit post 0.94,
but that's another story.
Anyway, first place is the swift log (<scriptName>-<runId>.log in the
directory where you ran swift).
The second place, if the previous one fails, is
~/.globus/coasters/*.log.
There is yet another place that isn't enabled by default. That's the
coaster worker logs. It can be enabled by saying <profile
namespace="globus" key="workerLoggingLevel">DEBUG</profile> in
sites.xml. It will produce some additional logs in ~/.globus/coasters/.
Please feel free to send any/all these our way. We might be able to
quickly spot some obvious problems.
Mihael
On Wed, 2014-05-21 at 23:59 +0000, Bronevetsky, Greg wrote:
> Where should I look to debug the following error?
> Caused by: Block task failed: 0521-5404270-000009 Block task ended prematurely
> Greg Bronevetsky
> Lawrence Livermore National Lab
> (925) 424-5756
> bronevetsky at llnl.gov
> http://greg.bronevetsky.com
> -----Original Message-----
> From: Mihael Hategan [mailto:hategan at mcs.anl.gov]
> Sent: Wednesday, May 21, 2014 2:10 PM
> To: Bronevetsky, Greg
> Cc: swift-user at ci.uchicago.edu
> Subject: Re: [Swift-user] Data transfer error
> Hi,
> Sorry for the late reply (to your previous mail mentioning this).
> I don't know what the answer to your question is. It shouldn't be happening.
> However, a directory called <scriptName>-<timestamp>-<runid>.d should be created by swift. That directory should contain one or more *.info file which may contain a few more details.
> Mihael
> On Wed, 2014-05-21 at 20:50 +0000, Bronevetsky, Greg wrote:
> > Related question: what causes the following error?
> > Caused by: Failed to move output file
> > solver_bicg.precond_diag.mtx_nasa1824/FI/blocks/block_10 to shared directory I see the file in the swift work directory and the path solver_bicg.precond_diag.mtx_nasa1824/FI/blocks/ exists in the directory where I run the script.
> > Greg Bronevetsky
> > (925) 424-5756
> > bronevetsky at llnl.gov<mailto:bronevetsky at llnl.gov>
> > From: Bronevetsky, Greg
> > Sent: Tuesday, May 20, 2014 2:11 PM
> > To: swift-user at ci.uchicago.edu
> > Subject: Data transfer error
> > I sometimes get the following error in my Swift runs:
> > solver_bicg.precond_diag.mtx_nasa1824/mt_fmodel/fm_n/lm_local/allStats to shared directory What causes it and how can I avoid it?
> > Greg Bronevetsky
> > (925) 424-5756
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
