[Swift-user] Swift on MOAB
David Kelly davidkelly at uchicago.edu
Wed Mar 5 16:14:34 CST 2014
Hi Greg,
I think having a script that translates from showq output to qstat style
output is possible. Could you please send some example showq output from
your cluster? Thanks!
David
On Tue, Mar 4, 2014 at 6:53 PM, Bronevetsky, Greg <bronevetsky1 at llnl.gov>wrote:
>  After some poking around I got it to mostly work. One issue is that
> although Moab accepts PBS scripts it does not implement its commands, such
> as qsub and qstat. I was able to overcome the first issue by creating a
> soft link named "qsub" that points to msub. However, I don't know what to
> do about qstat. When I do the same linking trick Swift throws errors,
> probably because it cannot parse the output. Is there a script that takes
> the output of showq and formats it qstat style? Thanks!
> Greg Bronevetsky
> Lawrence Livermore National Lab
> (925) 424-5756
> bronevetsky at llnl.gov
> http://greg.bronevetsky.com
> *From:* Yadu Nand [mailto:yadudoc1729 at gmail.com]
> *Sent:* Friday, February 28, 2014 5:35 PM
> *To:* Bronevetsky, Greg
> *Cc:* swift-user at ci.uchicago.edu
> *Subject:* Re: [Swift-user] Swift on MOAB
> Hi Greg,
> I went through this page : https://computing.llnl.gov/tutorials/moab/ which
> mentions that PBS
> submit scripts are compatible with Moab. So the Swift PBS provider should
> work for you.
> If there are cluster specific details that differ, we could patch the
> existing PBS provider to work
> with your cluster.
> Thanks,
> Yadu
> On Wed, Feb 26, 2014 at 12:38 PM, Bronevetsky, Greg <bronevetsky1 at llnl.gov>
> wrote:
> I'm running on clusters that use MOAB as the main scheduler, with SLURM on
> each cluster. Jobs need to be submitted to MOAB. Is there a way for Swift
> to use MOAB as the scheduler? Thanks!
> Greg Bronevetsky
> (925) 424-5756
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140305/5bf6b359/attachment.html>
More information about the Swift-user mailing list
