[Swift-user] Swift on MOAB
Wilde, Michael J. wilde at mcs.anl.gov
Tue Mar 4 19:55:54 CST 2014
Greg, we've had discussions about making script-generation for local schedulers more template-driven, and (eg for qstat) use local adapter scripts to a common job-status format (typically jobid + completion-status).
We'll see if we can give you a quick temporary solution, or if you want to help out, some advice on how to proceed.
- Mike
From: <Bronevetsky>, Greg <bronevetsky1 at llnl.gov<mailto:bronevetsky1 at llnl.gov>>
Date: Tuesday, March 4, 2014 6:53 PM
To: Yadu Nand <yadudoc1729 at gmail.com<mailto:yadudoc1729 at gmail.com>>
Cc: Swift User <swift-user at ci.uchicago.edu<mailto:swift-user at ci.uchicago.edu>>
Subject: Re: [Swift-user] Swift on MOAB
After some poking around I got it to mostly work. One issue is that although Moab accepts PBS scripts it does not implement its commands, such as qsub and qstat. I was able to overcome the first issue by creating a soft link named “qsub” that points to msub. However, I don’t know what to do about qstat. When I do the same linking trick Swift throws errors, probably because it cannot parse the output. Is there a script that takes the output of showq and formats it qstat style? Thanks!
Greg Bronevetsky
Lawrence Livermore National Lab
(925) 424-5756
bronevetsky at llnl.gov<mailto:bronevetsky at llnl.gov>
http://greg.bronevetsky.com
Sent: Friday, February 28, 2014 5:35 PM
To: Bronevetsky, Greg
Cc: swift-user at ci.uchicago.edu<mailto:swift-user at ci.uchicago.edu>
Hi Greg,
I went through this page : https://computing.llnl.gov/tutorials/moab/ which mentions that PBS
submit scripts are compatible with Moab. So the Swift PBS provider should work for you.
If there are cluster specific details that differ, we could patch the existing PBS provider to work
with your cluster.
Yadu
On Wed, Feb 26, 2014 at 12:38 PM, Bronevetsky, Greg <bronevetsky1 at llnl.gov<mailto:bronevetsky1 at llnl.gov>> wrote:
I’m running on clusters that use MOAB as the main scheduler, with SLURM on each cluster. Jobs need to be submitted to MOAB. Is there a way for Swift to use MOAB as the scheduler? Thanks!
Greg Bronevetsky
(925) 424-5756<tel:%28925%29%20424-5756>
Swift-user mailing list
Swift-user at ci.uchicago.edu<mailto:Swift-user at ci.uchicago.edu>
https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140305/707e1436/attachment.html>
More information about the Swift-user mailing list
