[Swift-user] Sites.xml to swift.properties Conversion
Yadu Nand
yadudoc1729 at gmail.com
Tue Jun 17 16:48:51 CDT 2014
Hi David,
Isn't the swift.properties supposed to say : site=local,persistent-coaster
instead of the site variable being redefined in what looks like a single
swift.properties file ?
-Yadu
On Tue, Jun 17, 2014 at 4:46 PM, David Kelly <davidkelly at uchicago.edu>
wrote:
> Hi Matthew,
> The new config assumes the provider is just 'coaster' by default, but it's
> possible to override this and specify your own url (just a little more
> verbose). This property should do it:
> jobManager=coaster-persistent:local:local:http://localhost:56069
> I'll make a note to add documentation about non-'coaster' setups in the
> userguide.
> David
> On Tue, Jun 17, 2014 at 4:03 PM, Matthew Shaxted <Matthew.Shaxted at som.com>
> wrote:
>> Hi Swift support,
>> I am in the process of converting my 0.94 swift scripts to 0.95, and I am
>> having a bit of difficulties creating the correct sites properties from the
>> new swift.properties file.
>> I am trying to convert the sites.xml file below, and when I attempt to
>> identify site.persistent-coaster{provider=”coaster-persistent”…} in the
>> swift.properties file I am getting an “Error: Unknown property
>> site.persistent-coasters.provider”.
>> Can anyone please lend some insight on how to best convert from a
>> sites.xml to a swift.properties file? I am using Swift 0.95 RC6 swift-r7900
>> cog-r3908
>> Thanks,
>> Matthew
>> *0.94 Sites.xml File*
>> <config>
>> <pool handle="localhost">
>> <execution provider="coaster" jobmanager="local:local"/>
>> <profile namespace="karajan" key="jobThrottle">0</profile>
>> <profile namespace="karajan" key="initialScore">10000</profile>
>> <filesystem provider="local"/>
>> <workdirectory>{env.HOME}/work</workdirectory>
>> </pool>
>> <pool handle="persistent-coasters">
>> <execution provider="coaster-persistent"
>> url="http://localhost:56069"
>> <profile namespace="globus" key="workerManager">passive</profile>
>> <profile namespace="globus" key="jobsPerNode">2</profile>
>> <profile key="jobThrottle" namespace="karajan">.01999</profile>
>> <filesystem provider="local" url="none" />
>> <workdirectory>/tmp/shaxted</workdirectory>
>> </pool>
>> </config>
>> *My new swift.properties file look like below:*
>> sitedir.keep=true
>> wrapperlog.always.transfer=true
>> site.local {
>> tasksPerWorker=8
>> taskWalltime=00:15:00
>> maxJobs=1
>> workdir=/home/som/EnergyPlus/test/work
>> filesystem=local
>> app.local.echo=/bin/echo
>> site=local
>> site. persistent-coaster {
>> provider=coaster
>> tasksPerWorker=8
>> maxJobs=2
>> filesystem=local
>> app.persistent-coaster.echo=/bin/echo
>> site=persistent-coaster
>> MATTHEW SHAXTED
>> SKIDMORE, OWINGS & MERRILL LLP
>> 224 South Michigan Ave.
>> Chicago, IL 60604
>> TEL: 312.360.4368
>> FAX: 312.360.4545
>> matthew.shaxted at som.com
>> [image: cid:image9d6458.png at 2965c709.c87949ac]
>> WWW.SOM.COM <http://www.som.com/>
>> The information contained in this communication may be confidential, is
>> intended only for the use of the recipient(s) named above, and may be
>> legally privileged. If the reader of this message is not the intended
>> recipient, you are hereby notified that any dissemination, distribution, or
>> copying of this communication, or any of its contents, is strictly
>> prohibited and may be unlawful. If you have received this communication in
>> error, please return it to the sender immediately and delete the original
>> message and any copy of it from your computer system. If you have any
>> questions concerning this message, please contact the sender.
>> [image: cid:image93798a.gif at f078f826.ddd94773]
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140617/eb22aa2e/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140617/eb22aa2e/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140617/eb22aa2e/attachment-0001.png>
More information about the Swift-user
