[Swift-user] Sites.xml to swift.properties Conversion
David Kelly
davidkelly at uchicago.edu
Tue Jun 17 16:56:44 CDT 2014
Yes - if you want it to run on both sites by default, there should be one
line that says site=local,persistent-coaster.
On Tue, Jun 17, 2014 at 4:48 PM, Yadu Nand <yadudoc1729 at gmail.com> wrote:
> Hi David,
> Isn't the swift.properties supposed to say : site=local,persistent-coaster
> instead of the site variable being redefined in what looks like a single
> swift.properties file ?
> -Yadu
> On Tue, Jun 17, 2014 at 4:46 PM, David Kelly <davidkelly at uchicago.edu>
> wrote:
>> Hi Matthew,
>> The new config assumes the provider is just 'coaster' by default, but
>> it's possible to override this and specify your own url (just a little more
>> verbose). This property should do it:
>> jobManager=coaster-persistent:local:local:http://localhost:56069
>> I'll make a note to add documentation about non-'coaster' setups in the
>> userguide.
>> David
>> On Tue, Jun 17, 2014 at 4:03 PM, Matthew Shaxted <Matthew.Shaxted at som.com
>> > wrote:
>>> Hi Swift support,
>>> I am in the process of converting my 0.94 swift scripts to 0.95, and I
>>> am having a bit of difficulties creating the correct sites properties from
>>> the new swift.properties file.
>>> I am trying to convert the sites.xml file below, and when I attempt to
>>> identify site.persistent-coaster{provider=”coaster-persistent”…} in the
>>> swift.properties file I am getting an “Error: Unknown property
>>> site.persistent-coasters.provider”.
>>> Can anyone please lend some insight on how to best convert from a
>>> sites.xml to a swift.properties file? I am using Swift 0.95 RC6 swift-r7900
>>> cog-r3908
>>> Thanks,
>>> Matthew
>>> *0.94 Sites.xml File*
>>> <config>
>>> <pool handle="localhost">
>>> <execution provider="coaster" jobmanager="local:local"/>
>>> <profile namespace="karajan" key="jobThrottle">0</profile>
>>> <profile namespace="karajan" key="initialScore">10000</profile>
>>> <filesystem provider="local"/>
>>> <workdirectory>{env.HOME}/work</workdirectory>
>>> </pool>
>>> <pool handle="persistent-coasters">
>>> <execution provider="coaster-persistent"
>>> url="http://localhost:56069"
>>> <profile namespace="globus" key="workerManager">passive</profile>
>>> <profile namespace="globus" key="jobsPerNode">2</profile>
>>> <profile key="jobThrottle" namespace="karajan">.01999</profile>
>>> <filesystem provider="local" url="none" />
>>> <workdirectory>/tmp/shaxted</workdirectory>
>>> </pool>
>>> </config>
>>> *My new swift.properties file look like below:*
>>> sitedir.keep=true
>>> wrapperlog.always.transfer=true
>>> site.local {
>>> tasksPerWorker=8
>>> taskWalltime=00:15:00
>>> maxJobs=1
>>> workdir=/home/som/EnergyPlus/test/work
>>> filesystem=local
>>> app.local.echo=/bin/echo
>>> site=local
>>> site. persistent-coaster {
>>> provider=coaster
>>> tasksPerWorker=8
>>> maxJobs=2
>>> filesystem=local
>>> app.persistent-coaster.echo=/bin/echo
>>> site=persistent-coaster
>>> MATTHEW SHAXTED
>>> SKIDMORE, OWINGS & MERRILL LLP
>>> 224 South Michigan Ave.
>>> Chicago, IL 60604
>>> TEL: 312.360.4368
>>> FAX: 312.360.4545
>>> matthew.shaxted at som.com
>>> [image: cid:image9d6458.png at 2965c709.c87949ac]
>>> WWW.SOM.COM <http://www.som.com/>
>>> The information contained in this communication may be confidential, is
>>> intended only for the use of the recipient(s) named above, and may be
>>> legally privileged. If the reader of this message is not the intended
>>> recipient, you are hereby notified that any dissemination, distribution, or
>>> copying of this communication, or any of its contents, is strictly
>>> prohibited and may be unlawful. If you have received this communication in
>>> error, please return it to the sender immediately and delete the original
>>> message and any copy of it from your computer system. If you have any
>>> questions concerning this message, please contact the sender.
>>> [image: cid:image93798a.gif at f078f826.ddd94773]
>>> _______________________________________________
>>> Swift-user mailing list
>>> Swift-user at ci.uchicago.edu
>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Yadu Nand B
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140617/53be0689/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140617/53be0689/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140617/53be0689/attachment-0001.png>
More information about the Swift-user
