[Swift-user] Java version to build and run Swift
Guilherme Gall
gmgall at lncc.br
Tue Jun 3 09:36:52 CDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Em 02-06-2014 16:52, Mihael Hategan escreveu:
> Hi Guilherme,
> I cannot seem to reproduce this problem.
> Do you happen to have a swift log from a failed run, perhaps
> together with wrapper logs (found in the *.d directory)?
> Mihael
Hello Mihael,
I'm sending the logs of a run that causes the aforementioned "Failed
to link input file" error attached. It happens in two different
machines both with the same input data. I just modified the tc.data
and sites.xml files to reflect the differences between the
environments. A simpler script, like hello.swift from examples
directory, works fine in both machines.
A third machine with Swift built from trunk revision 7575 can run the
script that fails without any problem. Again, I'm using the same input
data and script that fails in the machines mentioned above.
Unfortunately I forgot which Java version I used to build this working
version. It's a development machine with more than one Java version
installed.
Guilherme Gall
CSR/LNCC
GPG Public Key ID: A65ED0D5
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.14 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJTjd2EAAoJEG9WBlOmXtDVJtQIANbmbMHVT1TC6HMAOaFu1W2u
+6Vt7gP3x0pHsYH1gE59AgUR+vwbfEr84Y5QB9O+Fgg3z18WC37RYeRqvqFGW5Hh
xNoMMuEtzK6kJIpJ3BscUasF662Nfqday1XR+3XPEhGWdiFvCOJeDvXImOAI+X1k
G6llhGezAaPvSYau8nf6ec6fOSv9fgfItkALiCr8BTN4zKibK2p9ZhzbtosCwpLh
pC3mGEj9Kje0toBlV2Rpfb49RDB9cDJ7/oNorfBJ0sYxhsCLLbcaQGiyN2BzHIC8
WoJi1UlYxf1B0GPbryog3yAoZ9hyjfL3SsaO72zuTLBHqYj1o8jh0fu/oxSoips=
=73hy
-----END PGP SIGNATURE-----
Type: application/gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140603/0ef4a608/attachment.bin>
More information about the Swift-user
