[Swift-user] Java version to build and run Swift
Mihael Hategan hategan at mcs.anl.gov
Mon Jun 2 14:52:52 CDT 2014
Hi Guilherme,
I cannot seem to reproduce this problem.
Do you happen to have a swift log from a failed run, perhaps together
with wrapper logs (found in the *.d directory)?
Mihael
On Mon, 2014-06-02 at 09:40 -0300, Guilherme Gall wrote:
> Em 30-05-2014 15:19, Mihael Hategan escreveu:
> > On Fri, 2014-05-30 at 11:17 -0300, Guilherme Gall wrote:
> >> Hi all,
> >> What version of Java should I use to build and run Swift trunk?
> > Oracle is the gold standard. The IBM JDK should work. GCJ never
> > did.
> > The version should be >= 1.6.
> Hi all,
> I forgot I wasn't using the last revision on trunk. By using an older
> revision I was trying to eliminate the "Failed to link input file"
> error that I reported via e-mail to this list April 4
> (http://lists.ci.uchicago.edu/pipermail/swift-user/2014-April/002822.html)
> Making the checkout of the last revision and rebuilding Swift with
> Java 1.8.0 the NullPointerException doesn't happens anymore. The
> "Failed to link input file" error persists, though.
> Best regards,
More information about the Swift-user mailing list
