[Swift-user] Java version to build and run Swift
Mihael Hategan hategan at mcs.anl.gov
Tue Jun 3 14:22:33 CDT 2014
So the problem seems to be that alt.asc is passed to the app twice. Once
through map_envs and once through output_maps.
I'm not sure whether this should or should not generally result in an
error (although it should be caught earlier and reported nicer if it
should). I'll think about it.
Mihael
On Tue, 2014-06-03 at 11:36 -0300, Guilherme Gall wrote:
> Em 02-06-2014 16:52, Mihael Hategan escreveu:
> > Hi Guilherme,
> > I cannot seem to reproduce this problem.
> > Do you happen to have a swift log from a failed run, perhaps
> > together with wrapper logs (found in the *.d directory)?
> > Mihael
> Hello Mihael,
> I'm sending the logs of a run that causes the aforementioned "Failed
> to link input file" error attached. It happens in two different
> machines both with the same input data. I just modified the tc.data
> and sites.xml files to reflect the differences between the
> environments. A simpler script, like hello.swift from examples
> directory, works fine in both machines.
> A third machine with Swift built from trunk revision 7575 can run the
> script that fails without any problem. Again, I'm using the same input
> data and script that fails in the machines mentioned above.
> Unfortunately I forgot which Java version I used to build this working
> version. It's a development machine with more than one Java version
> installed.
More information about the Swift-user mailing list
