[Swift-user] Java version to build and run Swift
Guilherme Gall gmgall at lncc.br
Mon Jun 2 07:40:23 CDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Em 30-05-2014 15:19, Mihael Hategan escreveu:
> On Fri, 2014-05-30 at 11:17 -0300, Guilherme Gall wrote:
>> Hi all,
>> What version of Java should I use to build and run Swift trunk?
> Oracle is the gold standard. The IBM JDK should work. GCJ never
> did.
> The version should be >= 1.6.
Hi all,
I forgot I wasn't using the last revision on trunk. By using an older
revision I was trying to eliminate the "Failed to link input file"
error that I reported via e-mail to this list April 4
(http://lists.ci.uchicago.edu/pipermail/swift-user/2014-April/002822.html)
Making the checkout of the last revision and rebuilding Swift with
Java 1.8.0 the NullPointerException doesn't happens anymore. The
"Failed to link input file" error persists, though.
Best regards,
Guilherme Gall
CSR/LNCC
GPG Public Key ID: A65ED0D5
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.14 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJTjHC3AAoJEG9WBlOmXtDVSA8IAK7RlLYEUIedfnb+WyjkO28T
FP7H6HEruHD+MUmbMUH4yxFhXo5Qh4CWep0On+CfPxEcuzfSzozKuqY0ZeYDRTpg
5T39R+vgBgHmwUzajzwfeX18eBK/XtWW3ACaodB2/gE1JN/uGnuFvrEdDBdMmeqr
5cQFV/hrZOTEW5Trjtv5TOX6f8ihYBy2N2g4wandQQki3S3y+SvWNcaFvToABS0E
Ruwk1hXXOi8rqiCo6q6fhTFab0pOsvQfkfkFX4A4hfczseuvKkQE7vDbJBY8Bmnd
XJbpKooYxm9WB1k3Hhhpnr3OXHyEzndNwVQjJpAUbqZF8KbEfjddt1EyswRC+Zw=
=EiaM
-----END PGP SIGNATURE-----
More information about the Swift-user mailing list
