[Swift-user] Block task failed on Tukey/Cobalt
Justin M Wozniak
wozniak at mcs.anl.gov
Tue Feb 11 09:27:37 CST 2014
Has anyone else run successfully on Tukey?
Can you inspect/post the Swift-generated Cobalt submit script? You may
also want to inspect/post the Cobalt-generated
*.submit.stdout/*.submit.stderr logs.
On 02/10/2014 08:23 PM, Ketan Maheshwari wrote:
> Hi,
> Trying some Swift test for Swift-Galaxy demo on Tukey. Using
> local:cobalt coaster provider. I am getting the following error:
> $ swift -sites.file sites.xml -tc.file tc -config cf script.swift
> Swift 0.94 swift-r6637 cog-r3742
> RunID: 20140211-0216-ryo7slj7
> Progress: time: Tue, 11 Feb 2014 02:16:53 +0000
> Progress: time: Tue, 11 Feb 2014 02:17:23 +0000 Submitted:3
> Progress: time: Tue, 11 Feb 2014 02:17:53 +0000 Submitted:3
> Progress: time: Tue, 11 Feb 2014 02:17:58 +0000 Submitted:2 Active:1
> Execution failed:
> Exception in sh:
> Arguments:
> [gpfs/mira-home/ketan/galaxy-dist/database/files/000/dataset_1.dat, 0]
> Host: tukey
> Directory: script-20140211-0216-ryo7slj7/jobs/u/sh-uv25u9ml
> Caused by:
> Block task failed:
> anapp, script.swift, line 13
> Tried many different options in swift.properties to no avail.
> Also tried the ATPESC 2013 tutorial setup but scripts fail with same
> pattern/error messages.
> Attaching the tarball with config, sites file.
> Thanks for any suggestions.
> Ketan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140211/20b897ce/attachment.html>
More information about the Swift-user
