[Swift-user] env.HOME in sites file not working
Mihael Hategan hategan at mcs.anl.gov
Wed Dec 10 20:49:20 CST 2014
Variable substitution was done only in attributes but not in xml text
nodes. This should now be fixed in 0.95 swift r8324.
Mihael
On Wed, 2014-12-10 at 18:52 -0600, Ketan Maheshwari wrote:
> Hi,
> Running 0.95 swift-r8301 cog-r4045, the Swift run crashes when trying to
> set workdirectory to {env.HOME}/swiftwork but works if set with constant
> path.
> The error message is:
> Execution failed:
> Exception in dsp:
>     Arguments: [-f,
> __root__/lcrc/project/NEXTGENOPT/DSP_old/examples/smps/dcap/dcap243_200,
> -a, 1, -n, 1, -p, 1, -I, 10]
>     Host: localblues
>     Directory: dsp.blues-run001/jobs/j/dsp-j4e17i1m
> exception @ swift-int.k, line: 530
> Caused by: null
> Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
> Job failed with an exit code of 127
> Attached are two identical runs: run001.tgz which failed and run002.tgz
> which worked.
> How can I make it work so that the Swift workdir us not hardcoded?
> Thanks,
> Ketan
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
