[Swift-user] env.HOME in sites file not working
Ketan Maheshwari
ketan at mcs.anl.gov
Wed Dec 10 18:52:01 CST 2014
Running 0.95 swift-r8301 cog-r4045, the Swift run crashes when trying to
set workdirectory to {env.HOME}/swiftwork but works if set with constant
path.
The error message is:
Execution failed:
Exception in dsp:
Arguments: [-f,
__root__/lcrc/project/NEXTGENOPT/DSP_old/examples/smps/dcap/dcap243_200,
-a, 1, -n, 1, -p, 1, -I, 10]
Host: localblues
Directory: dsp.blues-run001/jobs/j/dsp-j4e17i1m
exception @ swift-int.k, line: 530
Caused by: null
Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
Job failed with an exit code of 127
Attached are two identical runs: run001.tgz which failed and run002.tgz
which worked.
How can I make it work so that the Swift workdir us not hardcoded?
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141210/d2a82f02/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141210/d2a82f02/attachment.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141210/d2a82f02/attachment-0001.bin>
More information about the Swift-user
