[Swift-user] env.HOME in sites file not working
Ketan Maheshwari
ketan at mcs.anl.gov
Thu Dec 11 11:59:05 CST 2014
Mihael,
I updated Swift to:
Swift 0.95 swift-r8326 cog-r4045
It still does not seem to work. The rundir is attached.
Ketan
On Wed, Dec 10, 2014 at 8:49 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Variable substitution was done only in attributes but not in xml text
> nodes. This should now be fixed in 0.95 swift r8324.
> Mihael
> On Wed, 2014-12-10 at 18:52 -0600, Ketan Maheshwari wrote:
> > Hi,
> > Running 0.95 swift-r8301 cog-r4045, the Swift run crashes when trying to
> > set workdirectory to {env.HOME}/swiftwork but works if set with constant
> > path.
> > The error message is:
> > Execution failed:
> > Exception in dsp:
> > Arguments: [-f,
> > __root__/lcrc/project/NEXTGENOPT/DSP_old/examples/smps/dcap/dcap243_200,
> > -a, 1, -n, 1, -p, 1, -I, 10]
> > Host: localblues
> > Directory: dsp.blues-run001/jobs/j/dsp-j4e17i1m
> > exception @ swift-int.k, line: 530
> > Caused by: null
> > Caused by: org.globus.cog.abstraction.impl.common.execution.JobException:
> > Job failed with an exit code of 127
> > Attached are two identical runs: run001.tgz which failed and run002.tgz
> > which worked.
> > How can I make it work so that the Swift workdir us not hardcoded?
> > Thanks,
> > Ketan
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141211/f333f9fd/attachment.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20141211/f333f9fd/attachment.bin>
More information about the Swift-user
