[Swift-user] Block task failed: Connection to worker lost
    Ozik, Jonathan
    jozik at anl.gov
    Sat Dec  6 12:02:52 CST 2014
All the simulation runs completed successfully. Thanks!
Let me know if you’d like to see any of the worker logs.
Jonathan
> On Dec 5, 2014, at 2:54 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Fri, 2014-12-05 at 14:13 -0600, Ozik, Jonathan wrote:
>> Great, very helpful.
>> If in my swift.conf I use:
>> staging: swift
>> filesystem: local
>> Will this result in symlinks or cp?
> Symlinks. Well, an initial copy to a "site directory" and then symlink
> from there. Again, this is what you had with 0.95.
> My suggestions are based on you getting something working, although
> perhaps not optimally, but working. And then optimizing I/O if needed
> with fancier staging schemes.
> Mihael
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
