[Swift-user] Block task failed: Connection to worker lost
Mihael Hategan hategan at mcs.anl.gov
Fri Dec 5 14:54:08 CST 2014
On Fri, 2014-12-05 at 14:13 -0600, Ozik, Jonathan wrote:
> Great, very helpful.
> If in my swift.conf I use:
> staging: swift
> filesystem: local
> Will this result in symlinks or cp?
Symlinks. Well, an initial copy to a "site directory" and then symlink
from there. Again, this is what you had with 0.95.
My suggestions are based on you getting something working, although
perhaps not optimally, but working. And then optimizing I/O if needed
with fancier staging schemes.
Mihael
More information about the Swift-user mailing list
