[Swift-user] Block task failed: Connection to worker lost
Mihael Hategan hategan at mcs.anl.gov
Sat Dec 6 12:26:50 CST 2014
Hi Jonathan,
I wouldn't mind the swift log to run it through the log analysis tools.
Mihael
On Sat, 2014-12-06 at 12:02 -0600, Ozik, Jonathan wrote:
> All the simulation runs completed successfully. Thanks!
> Let me know if you’d like to see any of the worker logs.
> Jonathan
> > On Dec 5, 2014, at 2:54 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > On Fri, 2014-12-05 at 14:13 -0600, Ozik, Jonathan wrote:
> >> Great, very helpful.
> >> If in my swift.conf I use:
> >> staging: swift
> >> filesystem: local
> >> Will this result in symlinks or cp?
> > Symlinks. Well, an initial copy to a "site directory" and then symlink
> > from there. Again, this is what you had with 0.95.
> > My suggestions are based on you getting something working, although
> > perhaps not optimally, but working. And then optimizing I/O if needed
> > with fancier staging schemes.
> > Mihael
> > _______________________________________________
> > Swift-user mailing list
> > Swift-user at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
