[Swift-user] Block task failed: Connection to worker lost
    Ozik, Jonathan
    jozik at anl.gov
    Fri Dec  5 14:13:23 CST 2014
Great, very helpful.
If in my swift.conf I use:
staging: swift
filesystem: local
Will this result in symlinks or cp?
Jonathan
> On Dec 5, 2014, at 2:05 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Hi Jonathan,
> Inline...
> On Fri, 2014-12-05 at 13:32 -0600, Ozik, Jonathan wrote:
>>> http://swift-lang.org/guides/trunk/userguide/userguide.html#table-staging-methods
>> Yes I did see the Swift Staging Methods table. Because I didn’t see
>> any reference to the “direct” staging I was wondering if I’d missed
>> any other document that was out there. But I’m guessing this means no.
> Direct staging (or more accurately the bypassing of staging) is a new
> feature that we are still testing and refining.
>> So for now, for running on a shared file system resource like Midway I should focus on local, direct or shared-fs staging?
> And "swift". This is what you were using with 0.95.
> Mihael
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
