[Swift-user] Converting sites configuration
David Kelly
davidkelly at uchicago.edu
Mon Apr 14 13:13:39 CDT 2014
Hi Guilherme,
I'm not immediately sure it's failing to link inputs. Could you please send
a log file from when this happens so I can take a closer look?
David
On Thu, Apr 10, 2014 at 2:08 PM, Guilherme Gall <gmgall at lncc.br> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Em 04-04-2014 02:18, David Kelly escreveu:
> > Hi Guilherme,
> > There was one setting (pe) that was undocumented and not yet in the
> > new config. I've just added this and updated the user guide. I've
> > attached a swift.properties file that I believe should work for you
> > with the latest 0.95 and trunk. Please let me know if you have any
> > issues.
> > I will add something to the user guide soon that makes it easier
> > to translate settings directly from sites.xml to the new
> > swift.properties format.
> > Thanks, David
> Hi David,
> The swift.properties that you sent me seems to work.
> But now I'm having another problem that wasn't happening before.
> Follows the error message that I receive sometimes:
> RunID: run011
> Progress: Qui, 10 abr 2014 14:58:18-0300
> Progress: Qui, 10 abr 2014 14:58:19-0300 Stage in:1
> Progress: Qui, 10 abr 2014 14:58:20-0300 Active:1
> Execution failed:
> Exception in generate_requests:
> Arguments: [-o, teste.txt, --min_occurrences, 10, --map_list,
> workshop/Brasil_ASC/alt.asc,workshop/Brasil_ASC/bio12.asc,workshop/Brasil_ASC/bio2.asc,
> - -m, workshop/Brasil_ASC/bio9.asc, --output_format_file,
> workshop/Brasil_ASC/bio10.asc, --output_map_list,
> workshop/Brasil_ASC/alt.asc,workshop/Brasil_ASC/bio3.asc,
> - --output_mask_file, workshop/Brasil_ASC/bio8.asc]
> Host: sunhpc
> Directory:
> workflow-openmodeller-run011/jobs/b/generate_requests-b6u6c1pl
> exception @ swift-int.k, line: 520
> Caused by: Failed to link input file workshop/Brasil_ASC/alt.asc
> throw @ swift-int.k, line: 68
> k:assign @ swift.k, line: 194
> Caused by: Exception in generate_requests:
> Host: sunhpc
> Directory:
> This is happening in 2 different environments with Swift installed.
> Both with recent code from trunk. One of them is using revision 7758
> and another 7759 (both from April 2014).
> There is a third machine using Swift revision 7575 that works
> perfectly. That was the environment that I used to develop my Swift
> script[1]. It always worked fine there.
> Is there the possibility of a recent change has generated a bug?
> Best regasrds,
> [1]
> https://github.com/sibbr/sdm-workflows/blob/master/workflow-openmodeller.swift
> Guilherme Gall
> CSR/LNCC
> GPG Public Key ID: A65ED0D5
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.14 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
> iQEcBAEBAgAGBQJTRuwhAAoJEG9WBlOmXtDV81EH/2r730TDR4bzc/s+F/jHUme5
> TR8Muw4bQcg/pY1gh7/yBkIXFjt6g9rc0nWEyYgWCK+dYImig1BfVqTQCu6u5xoZ
> pse4hRCC+Tsg+isJGfz5gKst5MQjXDjmE8Cy4Aw57qmlO/fPDGxXEo5ALkvJI9tZ
> NIGFygvp8vPsZ9BnfEY+qeoSMlFW+EGWQpfIVMKEmnZ1rKBQKQ64pf5ATXa6v9aL
> +koBJkeC5H2M0uZ9OEgfbLLJQvNiJ7fEQvlVQ7WdwNNEUWp0qLZdpA/aZqr8Lo8x
> EiLW/FFc3ISOuQGSsKWyM9EPOYgBXT9HDZLx19GTtckyW53VKQCVrnOf822Q86k=
> =iUZP
> -----END PGP SIGNATURE-----
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140414/b9374620/attachment.html>
More information about the Swift-user
