[Swift-user] Converting sites configuration
Guilherme Gall
gmgall at lncc.br
Thu Apr 10 14:08:17 CDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Em 04-04-2014 02:18, David Kelly escreveu:
> Hi Guilherme,
> There was one setting (pe) that was undocumented and not yet in the
> new config. I've just added this and updated the user guide. I've
> attached a swift.properties file that I believe should work for you
> with the latest 0.95 and trunk. Please let me know if you have any
> issues.
> I will add something to the user guide soon that makes it easier
> to translate settings directly from sites.xml to the new
> swift.properties format.
> Thanks, David
Hi David,
The swift.properties that you sent me seems to work.
But now I'm having another problem that wasn't happening before.
Follows the error message that I receive sometimes:
RunID: run011
Progress: Qui, 10 abr 2014 14:58:18-0300
Progress: Qui, 10 abr 2014 14:58:19-0300 Stage in:1
Progress: Qui, 10 abr 2014 14:58:20-0300 Active:1
Execution failed:
Exception in generate_requests:
Arguments: [-o, teste.txt, --min_occurrences, 10, --map_list,
workshop/Brasil_ASC/alt.asc,workshop/Brasil_ASC/bio12.asc,workshop/Brasil_ASC/bio2.asc,
- -m, workshop/Brasil_ASC/bio9.asc, --output_format_file,
workshop/Brasil_ASC/bio10.asc, --output_map_list,
workshop/Brasil_ASC/alt.asc,workshop/Brasil_ASC/bio3.asc,
- --output_mask_file, workshop/Brasil_ASC/bio8.asc]
Host: sunhpc
Directory:
workflow-openmodeller-run011/jobs/b/generate_requests-b6u6c1pl
exception @ swift-int.k, line: 520
Caused by: Failed to link input file workshop/Brasil_ASC/alt.asc
throw @ swift-int.k, line: 68
k:assign @ swift.k, line: 194
Caused by: Exception in generate_requests:
Host: sunhpc
Directory:
This is happening in 2 different environments with Swift installed.
Both with recent code from trunk. One of them is using revision 7758
and another 7759 (both from April 2014).
There is a third machine using Swift revision 7575 that works
perfectly. That was the environment that I used to develop my Swift
script[1]. It always worked fine there.
Is there the possibility of a recent change has generated a bug?
Best regasrds,
[1]
https://github.com/sibbr/sdm-workflows/blob/master/workflow-openmodeller.swift
Guilherme Gall
CSR/LNCC
GPG Public Key ID: A65ED0D5
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.14 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iQEcBAEBAgAGBQJTRuwhAAoJEG9WBlOmXtDV81EH/2r730TDR4bzc/s+F/jHUme5
TR8Muw4bQcg/pY1gh7/yBkIXFjt6g9rc0nWEyYgWCK+dYImig1BfVqTQCu6u5xoZ
pse4hRCC+Tsg+isJGfz5gKst5MQjXDjmE8Cy4Aw57qmlO/fPDGxXEo5ALkvJI9tZ
NIGFygvp8vPsZ9BnfEY+qeoSMlFW+EGWQpfIVMKEmnZ1rKBQKQ64pf5ATXa6v9aL
+koBJkeC5H2M0uZ9OEgfbLLJQvNiJ7fEQvlVQ7WdwNNEUWp0qLZdpA/aZqr8Lo8x
EiLW/FFc3ISOuQGSsKWyM9EPOYgBXT9HDZLx19GTtckyW53VKQCVrnOf822Q86k=
=iUZP
-----END PGP SIGNATURE-----
More information about the Swift-user
