[Swift-user] Converting sites configuration
David Kelly davidkelly at uchicago.edu
Fri Apr 4 00:18:15 CDT 2014
Hi Guilherme,
There was one setting (pe) that was undocumented and not yet in the new
config. I've just added this and updated the user guide. I've attached a
swift.properties file that I believe should work for you with the latest
0.95 and trunk. Please let me know if you have any issues.
I will add something to the user guide soon that makes it easier to
translate settings directly from sites.xml to the new swift.properties
format.
David
On Thu, Apr 3, 2014 at 7:18 PM, Guilherme Gall <gmgall at lncc.br> wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi everyone,
> I'm trying to configure the sites that I intend to use to run jobs
> with the new style of configuration that centralizes the sites
> configuration in the swift.properties file [1].
> The localhost worked fine just setting initialScore, jobManager,
> filesystem and workdir directives. But I'm having troubles configuring
> Swift to use a local SGE queue.
> Is there any documentation available explaining how to convert the
> sites.xml style to the new style? I would like to centralize
> everything in the swift.properties file.
> I know that the following sites.xml works fine:
> <config>
>   <pool handle="sunhpc">
>     <gridftp url="local://localhost" />
>     <!-- <execution provider="sge" url="localhost" /> -->
>     <execution provider="coaster" jobmanager="local:sge"
> url="localhost" />
>     <profile namespace="globus" key="pe">mpi</profile>
>     <profile namespace="globus" key="queue">linux.q</profile>
>     <profile key="jobThrottle" namespace="karajan">1.27</profile>
>     <profile namespace="karajan" key="initialScore">624</profile>
>     <filesystem provider="local" url="none" />
>     <workdirectory>/prj/cenapadrj/gmgall/swiftwork</workdirectory>
>   </pool>
> </config>
> But I wasn't able to put this directives in the swift.properties file.
> [1]
> http://swift-lang.org/guides/trunk/userguide/userguide.html#_grouping_site_properties
> Thanks in advance,
> Guilherme Gall
> CSR/LNCC
> GPG Public Key ID: A65ED0D5
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.4.14 (GNU/Linux)
> Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
> iQEcBAEBAgAGBQJTPfpFAAoJEG9WBlOmXtDVocwH/1RvBYXve7MqWH4FkzMMQn3r
> 29/kysBeTHSFOQRv1FvFeiNQE1N6Mq04eGboTwvdnljWU73b0wz/Nnsh/bSuuYyP
> gGYpfyF9/kBkX6/tezjZqHV8M/3ltyrS2pI3HROjTgfCWqV0LHOVo2c2Qyw3pDM0
> apIFJu72cBS8VLcRudOCLn/EaTj/Yrj625S2tmwbt6hbIhelTfI/HmhxYVfYVYK9
> tPstRROfGqxBlFO2Qldakrh8yl33WgeR/4/1WDtmztrEfyxYHn/lRVzJ6lP7LThA
> TM8vYtFObGNmfJKmp7BvuHa55sVMA1JR0zvaacBNcgGmI0J9+lFxNuKWq1g66Tc=
> =Am59
> -----END PGP SIGNATURE-----
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140404/d07c503f/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140404/d07c503f/attachment.obj>
More information about the Swift-user mailing list
