[Swift-user] Cray XE6:: Swift appears to wait till nodes are empty before submitting new jobs.
David Kelly davidk at ci.uchicago.edu
Fri Jan 4 13:32:43 CST 2013
Lorenzo,
I think one way you can do this is by setting walltimes in tc.data.
beagle shortjob /bin/shortjob null null GLOBUS::maxwalltime="00:05:00"
beagle longjob /bin/longjob null null GLOBUS::maxwalltime="47:50:00"
For multiple jobsPerNode values, you could define two pool entries in sites.xml. Each entry could have a different value for jobsPerNode. Then modify your tc.data to point to the appropriate entry.
David
----- Original Message -----
> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
> To: "David Kelly" <davidk at ci.uchicago.edu>
> Cc: "Joe Urbanski" <jurbanski at ci.uchicago.edu>, swift-user at ci.uchicago.edu
> Sent: Friday, January 4, 2013 12:21:36 PM
> Subject: Re: [Swift-user] Cray XE6:: Swift appears to wait till nodes are empty before submitting new jobs.
> David,
> Thanks a lot for your reply.
> It is not an iterative call.
> I talked with Mike about it and I think that he solved the problem (I
> still need to test that):
> <profile namespace="globus" key="maxTime">172800</profile>
> <profile namespace="globus" key="maxwalltime">47:50:00</profile>
> prevented the second app to be send in the same coaster because there
> was not enough time given the maxwalltime setting.
> I just realized how different the app times actually are. Can you
> point me to where I can figure out how to instruct the swift that
> different apps have different maxwalltimes and can run a different
> number of jobs per node?
> I might have asked this question already, I know... I slowly make
> progress through the coding of all the apps I have to write.
> Thanks a lot,
> Lorenzo
> On Jan 4, 2013, at 12:05 PM, David Kelly wrote:
> > Lorenzo,
> > Could you please show an example of how you are trying to do this?
> > Are you using iterate?
> >> To: swift-user at ci.uchicago.edu
> >> Sent: Thursday, January 3, 2013 3:48:31 PM
> >> Subject: [Swift-user] Cray XE6:: Swift appears to wait till nodes
> >> I am making some small tests of sequential jobs and it seems like
> >> once
> >> step 1 is finished, step 2 doesn't start until enough step 1s have
> >> completed.
> >> I assumed that swift would be able to send a jobs to a node before
> >> completion.
> >> Does it have to do with submission settings?
> >> Lorenzo
> >> _______________________________________________
> >> Swift-user mailing list
> >> Swift-user at ci.uchicago.edu
> >> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user mailing list
