[Swift-user] Cray XE6:: Swift appears to wait till nodes are empty before submitting new jobs.
Lorenzo Pesce
lpesce at uchicago.edu
Fri Jan 4 14:13:39 CST 2013
My calls are a bit different, should I tc to something like this?
# custom entries
pbs GATKIntRecalWrapper /lustre/beagle/lpesce/Jason/SwiftRun3/gatkIntRecalWrapper.sh INSTALLED AMD64::LINUX ENV::TMP="/dev/shm/GATK_post2013-01-03_11:09:08" GLOBUS::maxwalltime="00:05:00"
pbs GATKBQRecalWrapper /lustre/beagle/lpesce/Jason/SwiftRun3/gatkBQRecalWrapper.sh INSTALLED AMD64::LINUX ENV::TMP="/dev/shm/GATK_post2013-01-03_11:09:08" GLOBUS::maxwalltime="01:05:00"
pbs PicardMarkDuplWrapper /lustre/beagle/lpesce/Jason/SwiftRun3/picardMarkDuplWrapper.sh INSTALLED AMD64::LINUX ENV::TMP="/dev/shm/GATK_post2013-01-03_11:09:08" GLOBUS::maxwalltime="00:15:00"
On Jan 4, 2013, at 1:32 PM, David Kelly wrote:
> Lorenzo,
> I think one way you can do this is by setting walltimes in tc.data.
> beagle shortjob /bin/shortjob null null GLOBUS::maxwalltime="00:05:00"
> beagle longjob /bin/longjob null null GLOBUS::maxwalltime="47:50:00"
> For multiple jobsPerNode values, you could define two pool entries in sites.xml. Each entry could have a different value for jobsPerNode. Then modify your tc.data to point to the appropriate entry.
I will look up in the guide to understand this better, but the pointer you gave me should be enough. Thanks.
Thanks a lot David,
Lorenzo
> David
>> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
>> To: "David Kelly" <davidk at ci.uchicago.edu>
>> Cc: "Joe Urbanski" <jurbanski at ci.uchicago.edu>, swift-user at ci.uchicago.edu
>> Sent: Friday, January 4, 2013 12:21:36 PM
>> Subject: Re: [Swift-user] Cray XE6:: Swift appears to wait till nodes are empty before submitting new jobs.
>> David,
>> Thanks a lot for your reply.
>> It is not an iterative call.
>> I talked with Mike about it and I think that he solved the problem (I
>> still need to test that):
>> <profile namespace="globus" key="maxTime">172800</profile>
>> <profile namespace="globus" key="maxwalltime">47:50:00</profile>
>> prevented the second app to be send in the same coaster because there
>> was not enough time given the maxwalltime setting.
>> I just realized how different the app times actually are. Can you
>> point me to where I can figure out how to instruct the swift that
>> different apps have different maxwalltimes and can run a different
>> number of jobs per node?
>> I might have asked this question already, I know... I slowly make
>> progress through the coding of all the apps I have to write.
>> Thanks a lot,
>> Lorenzo
>> On Jan 4, 2013, at 12:05 PM, David Kelly wrote:
>>> Lorenzo,
>>> Could you please show an example of how you are trying to do this?
>>> Are you using iterate?
>>>> To: swift-user at ci.uchicago.edu
>>>> Sent: Thursday, January 3, 2013 3:48:31 PM
>>>> Subject: [Swift-user] Cray XE6:: Swift appears to wait till nodes
>>>> I am making some small tests of sequential jobs and it seems like
>>>> once
>>>> step 1 is finished, step 2 doesn't start until enough step 1s have
>>>> completed.
>>>> I assumed that swift would be able to send a jobs to a node before
>>>> completion.
>>>> Does it have to do with submission settings?
>>>> Lorenzo
>>>> _______________________________________________
>>>> Swift-user mailing list
>>>> Swift-user at ci.uchicago.edu
>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
