[Swift-user] Swift crashing, says it requires a config property which is not documente
Michael Wilde
wilde at mcs.anl.gov
Fri Jul 6 13:21:25 CDT 2012
Jonathan, sorry, this should be documented (its a new property), but for now, just add "use.wrapper.staging=false" to your -config file when using trunk.
- Mike
----- Original Message -----
> From: "Jonathan Margoliash" <jmargolpeople at gmail.com>
> To: swift-user at ci.uchicago.edu
> Sent: Friday, July 6, 2012 11:26:53 AM
> Subject: [Swift-user] Swift crashing, says it requires a config property which is not documente
> Hello swift user base,
> Earlier today I tried running my swift scripts on the trunk version of
> swift (downloading and installing it as instructed under the
> "Development Version" heading of the swift downloads page). I added
> swift to my path, and then tried running my scripts, which produced
> the following error message:
> Execution failed:
> Swift config property "use.wrapper.staging" not found in Swift
> configuration [swift_files/config]
> There was no other output of the swift program. I tried looking in the
> online documentation for use.wrapper.staging or anything that looked
> like it, but could not find the setting. Can you explain to me what
> this configuration setting is supposed to do, why swift is crashing
> without it, and if I should add it to my config file? Thanks,
> Jonathan
> btw - swift_files/config is the location I store the config folder
> relative to the swift script being run. It is not built in to the
> error message.
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
More information about the Swift-user
