[Swift-user] surveyor
Jonathan Monette
jonmon at mcs.anl.gov
Tue Jan 24 17:32:26 CST 2012
Hello,
I am trying to run on survey from communicado. Below are the config files. What other options are there for auth.defaults. I do not have an ssh key set up on surveyor so I can't say
surveyor.alcf.anl.gov.type=key. The only other way to access surveyor is with OTP. Since I am using surveyor as a stepping stone to intrepid(which only has OTP) how do I specify to Swift to use OTP in auth.defaults. I was trying to use the new ssh-cl provider but that is only for execution. Swift complains about not being able to create the share directory so I assumed I couldn't say <filesystem="local"/> so I have been trying to change it to ssh.
sites.xml
<config>
<pool handle="surveyor">
<execution provider="coaster" jobmanager="ssh-cl:cobalt" url="surveyor.alcf.anl.gov" />
<filesystem provider="ssh" url="surveyor.alcf.anl.gov" />
<!-- <profile namespace="globus" key="internalHostname">172.17.3.13</profile> -->
<profile namespace="globus" key="project">MTCScienceApps</profile>
<profile namespace="globus" key="queue">short</profile>
<profile namespace="globus" key="kernelprofile">zeptoos</profile>
<profile namespace="globus" key="alcfbgpnat">true</profile>
<profile namespace="karajan" key="jobthrottle">21</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<profile namespace="globus" key="jobsPerNode">1</profile>
<profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
<profile namespace="globus" key="slots">1</profile>
<profile namespace="globus" key="maxTime">900</profile> <!-- seconds -->
<profile namespace="globus" key="nodeGranularity">64</profile>
<profile namespace="globus" key="maxNodes">64</profile>
<workdirectory>/home/jonmon/swift.workdir</workdirectory>
</pool>
</config>
tc
surveyor echo /bin/echo INSTALLED INTEL32::LINUX
surveyor cat /bin/cat INSTALLED INTEL32::LINUX
surveyor ls /bin/ls INSTALLED INTEL32::LINUX
surveyor grep /bin/grep INSTALLED INTEL32::LINUX
surveyor sort /bin/sort INSTALLED INTEL32::LINUX
surveyor paste /bin/paste INSTALLED INTEL32::LINUX
surveyor wc /usr/bin/wc INSTALLED INTEL32::LINUX
swiftscirpt
type file;
app (file o) echo()
echo "Hello World!!!" stdout=@o;
file output<"hello.txt">;
output = echo();
More information about the Swift-user
