[Swift-user] surveyor
Michael Wilde
wilde at mcs.anl.gov
Tue Jan 24 18:04:35 CST 2012
Jon, try configuring auth.defaults as you would for a password login, but dont specify a password. Swift should then prompt you for one (with a text prompt, assuming you are running Swift in a non-X setting). E.g.:
login1.pads.ci.uchicago.edu.type=password
login1.pads.ci.uchicago.edu.username=wilde
I dont know if the ssh provider will maintain a connection so that you only need to provide the OTP once. That might be an issue, if not.
- Mike
----- Original Message -----
> From: "Jonathan Monette" <jonmon at mcs.anl.gov>
> To: "swift user" <swift-user at ci.uchicago.edu>
> Sent: Tuesday, January 24, 2012 5:32:26 PM
> Subject: [Swift-user] surveyor
> Hello,
> I am trying to run on survey from communicado. Below are the config
> files. What other options are there for auth.defaults. I do not have
> an ssh key set up on surveyor so I can't say
> surveyor.alcf.anl.gov.type=key. The only other way to access surveyor
> is with OTP. Since I am using surveyor as a stepping stone to
> intrepid(which only has OTP) how do I specify to Swift to use OTP in
> auth.defaults. I was trying to use the new ssh-cl provider but that is
> only for execution. Swift complains about not being able to create the
> share directory so I assumed I couldn't say <filesystem="local"/> so I
> have been trying to change it to ssh.
> sites.xml
> <config>
> <pool handle="surveyor">
> <execution provider="coaster" jobmanager="ssh-cl:cobalt"
> url="surveyor.alcf.anl.gov" />
> <filesystem provider="ssh" url="surveyor.alcf.anl.gov" />
> <!-- <profile namespace="globus"
> key="internalHostname">172.17.3.13</profile> -->
> <profile namespace="globus" key="project">MTCScienceApps</profile>
> <profile namespace="globus" key="queue">short</profile>
> <profile namespace="globus" key="kernelprofile">zeptoos</profile>
> <profile namespace="globus" key="alcfbgpnat">true</profile>
> <profile namespace="karajan" key="jobthrottle">21</profile>
> <profile namespace="karajan" key="initialScore">10000</profile>
> <profile namespace="globus" key="jobsPerNode">1</profile>
> <profile namespace="globus" key="workerLoggingLevel">DEBUG</profile>
> <profile namespace="globus" key="slots">1</profile>
> <profile namespace="globus" key="maxTime">900</profile> <!-- seconds
> <profile namespace="globus" key="nodeGranularity">64</profile>
> <profile namespace="globus" key="maxNodes">64</profile>
> <workdirectory>/home/jonmon/swift.workdir</workdirectory>
> </pool>
> </config>
> tc
> surveyor echo /bin/echo INSTALLED INTEL32::LINUX
> surveyor cat /bin/cat INSTALLED INTEL32::LINUX
> surveyor ls /bin/ls INSTALLED INTEL32::LINUX
> surveyor grep /bin/grep INSTALLED INTEL32::LINUX
> surveyor sort /bin/sort INSTALLED INTEL32::LINUX
> surveyor paste /bin/paste INSTALLED INTEL32::LINUX
> surveyor wc /usr/bin/wc INSTALLED INTEL32::LINUX
> swiftscirpt
> type file;
> app (file o) echo()
> echo "Hello World!!!" stdout=@o;
> file output<"hello.txt">;
> output = echo();
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
More information about the Swift-user
