[Swift-user] Files staged out with 0.93rc2, but not with trunk
Jonathan Monette jonmon at mcs.anl.gov
Tue Jan 24 19:07:23 CST 2012
I think  that was when Mihael added some garbage collection.  I think it was though that if the file was mapped with the concurrent mapper and it was no longer needed, then it could be removed.  If you want to keep the mapped files around longer then maybe use the single_file_mapper or the simple_mapper.
On Jan 24, 2012, at 5:03 PM, Thomas Uram wrote:
> Update:
> I'm not sure of the intention of Swift rev 4773:
> "clean up temporary variables (including file removal for the concurrent mapper)"
> https://trac.ci.uchicago.edu/swift/changeset/4773
> but it's removing the destination files after they've been staged out. I've disabled this for my purposes. If I'm to avoid this functionality in some other way,  let me know.
> Thanks,
> Tom
> On Jan 24, 2012, at 11:42 AM, Thomas Uram wrote:
>> With the same script, 0.93rc2 stages files out, but trunk does not. Log files are here (which conveniently include the script and config files):
>> http://www.mcs.anl.gov/~turam/20120124-1135/hostname-20120124-1131-uk1bexk9.093.log
>> http://www.mcs.anl.gov/~turam/20120124-1135/hostname-20120124-1128-cf8mo3pe.trunk.log
>> In the case of the trunk, the _concurrent directory is created, but files do not exist there.
>> I haven't dug deeply into this. I'm using trunk for the ssh-cl provider, but clearly also want the files to be staged out properly.
>> Thanks,
>> Tom
> Swift-user mailing list
> Swift-user at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20120124/cdf13008/attachment.html>
More information about the Swift-user mailing list
