[Swift-user] swift on midway: apps and modules
Neil Best nbest at ci.uchicago.edu
Thu Dec 20 10:24:20 CST 2012
On Mon, Dec 3, 2012 at 6:22 PM, Michael Wilde <wilde at mcs.anl.gov> wrote:
>   use.provider.staging=true
> Now your input data files will be copied to the node /scratch/local dir and your output files copied back.
I assume that coaster staging will only work if the inputs are
explicitly mapped, right?  My app works by giving a path as a
parameter.  The script fired by the app finds its inputs there.  I
guess I need some kind of spoof in that case.
More information about the Swift-user mailing list
