[Swift-user] swift on midway: apps and modules
Michael Wilde
wilde at mcs.anl.gov
Thu Dec 20 11:07:51 CST 2012
> I assume that coaster staging will only work if the inputs are
> explicitly mapped, right?
Thats right. The files to be staged must be mapped using standard Swift mapping constructs. Files that are accessed by passing strings will not be seen by Swift and hence not staged by provider staging (or any other automatic Swift staging).
> My app works by giving a path as a
> parameter. The script fired by the app finds its inputs there. I
> guess I need some kind of spoof in that case.
You'll need to map all files to take advantage of provider staging.
- Mike
More information about the Swift-user
