[Swift-user] Error message on Cray XE6
Michael Wilde
wilde at mcs.anl.gov
Sat Apr 14 09:58:22 CDT 2012
/home is no longer mounted by the compute nodes, per the post-maitenance summary:
"External filesystem dependencies minimized: Compute nodes and the scheduler should now continue to process and complete jobs without the threat of interference of external filesystem outages. /gpfs/pads is only available on login1 through login5; /home is on login and mom nodes only."
So we need to (finally) remove Swift's dependence on $HOME/.globus and $HOME/.globus/scripts in particular.
I suggest - since the swift command already needs to write to "." - that we create a scripts/ directory in "." instead of $HOME/.globus. And this should be used by any provider that would have previously created files below .globus.
I'll echo this to swift-devel and start a thread there to discuss. Its possible there's already a property to cause scripts/ to be created elsewhere. If not, I think we should make one. I think grouping the scripts created by a run into the current dir, along with the swift log, _concurrent, and (in the conventions I use in my run scripts) swiftwork/.
Lorenzo, hopefully we can at least get you a workaround for this soon.
You *might* be able to trick swift into doing this by setting HOME=/lustre/beagle/$USER. I already tried a symlink under .globus and that didnt work, as /home is not even readable by the compute nodes, which in this case need to run the coaster worker (.pl) script.
- Mike
----- Original Message -----
> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
> To: "Jonathan Monette" <jonmon at mcs.anl.gov>
> Cc: swift-user at ci.uchicago.edu
> Sent: Saturday, April 14, 2012 8:15:39 AM
> Subject: Re: [Swift-user] Error message on Cray XE6
> In principle the access to the /home filesystem should still be there.
> The only thing I did was to chance the cf file to remove some errors I
> had into it, so that might also be the source of the problem. This is
> what it looks like now:
> (BTW, the comments are not mine, I run swift only from lustre)
> # Whether to transfer the wrappers from the compute nodes
> # I like to launch from my home dir, but keep everything on
> # lustre
> wrapperlog.always.transfer=false
> #Indicates whether the working directory on the remote site
> # should be left intact even when a run completes successfully
> sitedir.keep=true
> #try only once
> execution.retries=1
> # Attempt to run as much as possible, i.g., ignore non-fatal errors
> lazy.errors=true
> # to reduce filesystem access
> status.mode=provider
> use.provider.staging=false
> provider.staging.pin.swiftfiles=false
> foreach.max.threads=100
> provenance.log=false
> On Apr 14, 2012, at 12:10 AM, Jonathan Monette wrote:
> > The perl script is the worker script that is submitted with PBS. I
> > have not tried to run on Beagle since the maintenance period has
> > ended so I am not exactly sure why the error popped up. One reason
> > could be that the home file system is no longer mounted on the
> > compute nodes. I know they spoke about that being a possibility but
> > not sure they implemented that during the maintenance period. Do you
> > know if the home file system is still mounted on the compute nodes?
> > On Apr 13, 2012, at 17:18, Lorenzo Pesce <lpesce at uchicago.edu>
> > wrote:
> >> Hi --
> >> I haven't seen this one before:
> >> Can't open perl script
> >> "/home/lpesce/.globus/coasters/cscript7176272791806289394.pl": No
> >> such file or directory
> >> The config of the cray has changed, might this have anything to do
> >> with it?
> >> I have no idea what perl script is it talking about and why it is
> >> looking to home.
> >> Thanks a lot,
> >> Lorenzo
> >> _______________________________________________
> >> Swift-user mailing list
> >> Swift-user at ci.uchicago.edu
> >> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
Michael Wilde
Computation Institute, University of Chicago
Mathematics and Computer Science Division
Argonne National Laboratory
More information about the Swift-user
