[Swift-user] Error message on Cray XE6
Jonathan Monette jonmon at mcs.anl.gov
Sat Apr 14 10:02:14 CDT 2012
That is an easy fix I believe. I know where the code is so I will change and test.
In the mean time could you try something? Try setting user.home=<someplace.on.lustre>
in your config file and try again.
On Apr 14, 2012, at 9:58, Michael Wilde <wilde at mcs.anl.gov> wrote:
> /home is no longer mounted by the compute nodes, per the post-maitenance summary:
> "External filesystem dependencies minimized: Compute nodes and the scheduler should now continue to process and complete jobs without the threat of interference of external filesystem outages. /gpfs/pads is only available on login1 through login5; /home is on login and mom nodes only."
> So we need to (finally) remove Swift's dependence on $HOME/.globus and $HOME/.globus/scripts in particular.
> I suggest - since the swift command already needs to write to "." - that we create a scripts/ directory in "." instead of $HOME/.globus. And this should be used by any provider that would have previously created files below .globus.
> I'll echo this to swift-devel and start a thread there to discuss. Its possible there's already a property to cause scripts/ to be created elsewhere. If not, I think we should make one. I think grouping the scripts created by a run into the current dir, along with the swift log, _concurrent, and (in the conventions I use in my run scripts) swiftwork/.
> Lorenzo, hopefully we can at least get you a workaround for this soon.
> You *might* be able to trick swift into doing this by setting HOME=/lustre/beagle/$USER. I already tried a symlink under .globus and that didnt work, as /home is not even readable by the compute nodes, which in this case need to run the coaster worker (.pl) script.
> - Mike
>> From: "Lorenzo Pesce" <lpesce at uchicago.edu>
>> To: "Jonathan Monette" <jonmon at mcs.anl.gov>
>> Cc: swift-user at ci.uchicago.edu
>> Sent: Saturday, April 14, 2012 8:15:39 AM
>> Subject: Re: [Swift-user] Error message on Cray XE6
>> In principle the access to the /home filesystem should still be there.
>> The only thing I did was to chance the cf file to remove some errors I
>> had into it, so that might also be the source of the problem. This is
>> what it looks like now:
>> (BTW, the comments are not mine, I run swift only from lustre)
>> # Whether to transfer the wrappers from the compute nodes
>> # I like to launch from my home dir, but keep everything on
>> # lustre
>> wrapperlog.always.transfer=false
>> #Indicates whether the working directory on the remote site
>> # should be left intact even when a run completes successfully
>> sitedir.keep=true
>> #try only once
>> execution.retries=1
>> # Attempt to run as much as possible, i.g., ignore non-fatal errors
>> lazy.errors=true
>> # to reduce filesystem access
>> status.mode=provider
>> use.provider.staging=false
>> provider.staging.pin.swiftfiles=false
>> foreach.max.threads=100
>> provenance.log=false
>> On Apr 14, 2012, at 12:10 AM, Jonathan Monette wrote:
>>> The perl script is the worker script that is submitted with PBS. I
>>> have not tried to run on Beagle since the maintenance period has
>>> ended so I am not exactly sure why the error popped up. One reason
>>> could be that the home file system is no longer mounted on the
>>> compute nodes. I know they spoke about that being a possibility but
>>> not sure they implemented that during the maintenance period. Do you
>>> know if the home file system is still mounted on the compute nodes?
>>> On Apr 13, 2012, at 17:18, Lorenzo Pesce <lpesce at uchicago.edu>
>>> wrote:
>>>> Hi --
>>>> I haven't seen this one before:
>>>> Can't open perl script
>>>> "/home/lpesce/.globus/coasters/cscript7176272791806289394.pl": No
>>>> such file or directory
>>>> The config of the cray has changed, might this have anything to do
>>>> with it?
>>>> I have no idea what perl script is it talking about and why it is
>>>> looking to home.
>>>> Thanks a lot,
>>>> Lorenzo
>>>> _______________________________________________
>>>> Swift-user mailing list
>>>> Swift-user at ci.uchicago.edu
>>>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Michael Wilde
> Computation Institute, University of Chicago
> Mathematics and Computer Science Division
> Argonne National Laboratory
More information about the Swift-user mailing list
