[Swift-user] Error message on Cray XE6
Lorenzo Pesce
lpesce at uchicago.edu
Sat Apr 14 08:15:39 CDT 2012
In principle the access to the /home filesystem should still be there.
The only thing I did was to chance the cf file to remove some errors I had into it, so that might also be the source of the problem. This is what it looks like now:
(BTW, the comments are not mine, I run swift only from lustre)
# Whether to transfer the wrappers from the compute nodes
# I like to launch from my home dir, but keep everything on
# lustre
wrapperlog.always.transfer=false
#Indicates whether the working directory on the remote site
# should be left intact even when a run completes successfully
sitedir.keep=true
#try only once
execution.retries=1
# Attempt to run as much as possible, i.g., ignore non-fatal errors
lazy.errors=true
# to reduce filesystem access
status.mode=provider
use.provider.staging=false
provider.staging.pin.swiftfiles=false
foreach.max.threads=100
provenance.log=false
On Apr 14, 2012, at 12:10 AM, Jonathan Monette wrote:
> The perl script is the worker script that is submitted with PBS. I have not tried to run on Beagle since the maintenance period has ended so I am not exactly sure why the error popped up. One reason could be that the home file system is no longer mounted on the compute nodes. I know they spoke about that being a possibility but not sure they implemented that during the maintenance period. Do you know if the home file system is still mounted on the compute nodes?
> On Apr 13, 2012, at 17:18, Lorenzo Pesce <lpesce at uchicago.edu> wrote:
>> Hi --
>> I haven't seen this one before:
>> Can't open perl script "/home/lpesce/.globus/coasters/cscript7176272791806289394.pl": No such file or directory
>> The config of the cray has changed, might this have anything to do with it?
>> I have no idea what perl script is it talking about and why it is looking to home.
>> Thanks a lot,
>> Lorenzo
>> Swift-user mailing list
>> Swift-user at ci.uchicago.edu
>> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
More information about the Swift-user
