[Swift-user] gram on ranger
Sarah Kenny
skenny at uchicago.edu
Tue Oct 11 13:32:37 CDT 2011
so, this workflow completes all the jobs but then just hangs indefinitely at
the end...maybe a stray cleanup job?
log is here:
/home/skenny/swift_logs/corr-20111010-2104-fl5yngd9.log
just tweaked the sites file a bit from what david sent me:
<config>
<pool handle="RANGER">
<execution provider="coaster" jobManager="gt2:SGE" url="
gatekeeper.ranger.tacc.teragrid.org"/>
<filesystem provider="gsiftp" url="gsiftp://
gridftp.ranger.tacc.teragrid.org"/>
<profile namespace="globus" key="maxtime">28800</profile>
<profile namespace="globus" key="maxWallTime">00:15:00</profile>
<profile namespace="globus" key="jobsPerNode">1</profile>
<profile namespace="globus" key="nodeGranularity">64</profile>
<profile namespace="globus" key="maxNodes">256</profile>
<profile namespace="globus" key="queue">normal</profile>
<profile namespace="karajan" key="jobThrottle">1</profile>
<profile namespace="globus" key="project">TG-DBS080004N</profile>
<profile namespace="globus" key="pe">16way</profile>
<profile namespace="karajan" key="initialScore">10000</profile>
<workdirectory>/work/00043/tg457040/sidgrid_out/skenny</workdirectory>
</pool>
</config>
On Mon, Oct 10, 2011 at 3:43 PM, Sarah Kenny <skenny at uchicago.edu> wrote:
> ok, thanks, got in the queue now...also, realized my last run may have been
> using the old swift. apparently i had SWIFT_HOME set in my env and that
> overrides the newer swift i had set in my PATH.
> ~sk
> On Mon, Oct 10, 2011 at 12:28 PM, David Kelly <davidk at ci.uchicago.edu>wrote:
>> Sarah,
>> Can you give this another try with the latest 0.93? I made some changes to
>> the coaster and sge providers and was able to get it working with a simple
>> catns script. Here is the configuration file I was using:
>> <config>
>> <pool handle="ranger">
>> <profile namespace="globus" key="maxtime">3600</profile>
>> <profile namespace="globus" key="maxWallTime">00:00:03</profile>
>> <profile namespace="globus" key="nodeGranularity">16</profile>
>> <profile namespace="globus" key="maxNodes">16</profile>
>> <profile namespace="globus" key="queue">development</profile>
>> <profile namespace="karajan" key="jobThrottle">0.9</profile>
>> <workdirectory>/share/home/01503/davidkel/swiftwork</workdirectory>
>> </pool>
>> </config>
>> Thanks,
>> David
>> ----- Original Message -----
>> > From: "Sarah Kenny" <skenny at uchicago.edu>
>> > To: "Justin M Wozniak" <wozniak at mcs.anl.gov>
>> > Cc: "Swift Devel" <swift-devel at ci.uchicago.edu>, "Swift User" <
>> swift-user at ci.uchicago.edu>
>> > Sent: Friday, October 7, 2011 3:13:57 PM
>> > Subject: Re: [Swift-user] gram on ranger
>> > /home/skenny/swift_logs/dummy-20111005-0126-6575n7x5.log
>> > on ci
>> > On Fri, Oct 7, 2011 at 8:16 AM, Justin M Wozniak < wozniak at mcs.anl.gov
>> > > wrote:
>> > Can I take a look at the log?
>> > On Thu, 6 Oct 2011, Sarah Kenny wrote:
>> > hey all, i'm trying to submit to gram on ranger using the latest swift
>> > (built from trunk). it failes like so:
>> > Cannot submit job
>> > Caused by:
>> > org.globus.cog.abstraction. impl.common.task. TaskSubmissionException:
>> > Cannot
>> > submit job
>> > Caused by: org.globus.gram.GramException: Parameter not supported
>> > Cannot submit job
>> > the gram log was saying first that 'jobsPerNode' is not supported so i
>> > changed it to workersPerNode and then it was saying 'maxnodes' is not
>> > supported. here's my sites file:
>> > <config>
>> > <profile namespace="karajan" key="initialScore">10000</ profile>
>> > <profile namespace="globus" key="maxWallTime">00:15:00</ profile>
>> > <profile namespace="globus" key="maxTime">86400</profile>
>> > <profile namespace="globus" key="slots">1</profile>
>> > <profile namespace="globus" key="workersPerNode">1</ profile>
>> > <profile namespace="globus" key="nodeGranularity">64</ profile>
>> > <profile namespace="globus" key="project">TG-DBS080004N</ profile>
>> > gridftp.ranger.tacc.teragrid. org "/>
>> > <execution provider="coaster" jobManager="gt2:gt2:SGE" url="
>> > gatekeeper.ranger.tacc. teragrid.org "/>
>> > <execution provider="gt2" jobManager="SGE" url="
>> > <workdirectory>/work/00043/ tg457040</workdirectory>
>> > </pool>
>> > </config>
>> > thoughts? ideas?
>> > Justin M Wozniak
>> > Sarah Kenny
>> > Programmer ~ Brain Circuits Laboratory ~ Rm 2224 Bio Sci III
>> > University of California Irvine, Dept. of Neurology ~ 773-818-8300
>> > _______________________________________________
>> > Swift-user mailing list
>> > Swift-user at ci.uchicago.edu
>> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
> Sarah Kenny
Sarah Kenny
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20111011/e4b63ef4/attachment.html>
More information about the Swift-user
